Question about Vizio L32 32 in. LCD HDTV
Toshiba 32av502u remote codes
I want to be able to program my Direct TV remote to my new Toshiba 32AV502U TV. I can get the power to work, I can get the menu to work but the most important thing is the sound..and well that wont work. I was told to use code 12006 but that does the same thing...How do i get the sound to work on my Direct TV DVR remote?
  • Anonymous Feb 21, 2009
    We can't even get the power or menu buttons to work. How did you get that far?
  • 362 Answers
SOURCE: I need a manual for my Toshiba 32AV502U-
You can download manual here.
http://www.tacp.toshiba.com/customersupport/
Enter your model number and click on owners manual.
Lone99star
Posted on Mar 27, 2009
Bubbabear64
  • 2794 Answers
SOURCE: Directv Tivo recorder no remote programming code for Visio 37''
If it were a Tivo series 3 you might have better luck with it.
http://www.tivo.com/setupandsupport/technicalsupport/compatibilityhelp/Using_the_Learning_Feature_of_the_TiVo_Glo_or_Series3_Remote.html
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
Posted on Nov 22, 2008
  • 4 Answers
SOURCE: code for Vizio tv
Unfortunately, those remotes only take a 3 digit code. I bought 2 new remotes, which do take 4 digit codes, but the code(s) for the Vizio do not work (or partially). I found that the 4 digit codes for the Goldstar and LG work better than those provided for the Vizio, but still not as good as the original Vizio remote.
Posted on Apr 01, 2009
SOURCE: tv code for uverse remote
is it a motorola or sysco stb?
Posted on Apr 12, 2009
SOURCE: Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Posted on Sep 07, 2009
Program a universal remote control
There is a common procedure with all remotes, you need to look up your TV code, and most have directions on how to sequence the code to your TV, not hard at all.
FREE-PPV.com
Apr 21, 2015 | Toshiba 32AV502U 31.5 in. LCD HDTV
Toshiba lcd tv 32" making noise by speaker
test this steps and fix it. God bless you
Line noise is feeding in from the AC line. Use an AC liner filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
Jul 25, 2013 | Toshiba 32AV502U 31.5 in. LCD HDTV
Trouble with HDMI cable from Kindle Fire HD to model 32AV502U
Faulty HDMI port on your kindle. Best option return to manufacture.
Dec 13, 2017 | Toshiba 32AV502U 31.5 in. LCD HDTV
Screen Flicker/Speaker Pop on one HDMI
Look for loose contacts in jacks, sockets, cables. Look for loose contacts in power outlet.
Aug 03, 2012 | Toshiba 32AV502U 31.5 in. LCD HDTV
Volume on my Toshiba TV 32AV502U goes up on its own at random times. Remote brings the volume down but within minutes volume goes up again. Solution??
First off, take the batteries out of your remote to see if it is a problem with your remote, if it is I would buy a new universal remote and try that. If none of this works then the problem is with your tv itself. Either the volume button on the tv is broken and works on its own, or the tv is having programming errors and you will need to have it fixed.
Jun 26, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
I have a Toshiba Mod 32AV502U in which I am getting no volume? pls help
You are probably using an HDMI cable. Try using "Component" Cables instead (RED,GREEN,BLUE and WHITE, RED) These cables are still HD but work aound the no sound issue with Toshiba.
Jan 04, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
The volume on my toshiba 32AV502U TV is constantly going up on its own, ive checked the sensor by covering it and ive only recently discovered its the volume button. it fixed itself after 2 weeks and then...
i have had the same problem with tv.what i did is taped the volume up button on the tv a little hard and it has seemed to fix it for now.as of 1-12-2011 if it does not stay then i will disconnect the wires going to the volume switch.the switch is defective not the remote.
Dec 24, 2010 | Toshiba 32AV502U 31.5 in. LCD HDTV
Toshiba 32AV502U
As far as i remember Samsung makes all the screens Toshiba uses. I would try to contact Toshiba for a replacement screen, from what i've heard the price of the screen is comparable with the price of a new TV
hope this helps,
Thomas
Mar 03, 2010 | Toshiba 32AV502U 31.5 in. LCD HDTV
TV Ears won't work with new Toshiba tv
wrong ports
for antenna operation you need antenna in ports
Nov 03, 2017 | Toshiba 32AV502U 31.5 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
446 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
