Question about Saeco Magic De Luxe Espresso Machine
Water leaking from the tank & down the outside of the Magic DeLux
I've looked at the gasket in the main body of the machine and it looks fine. I believe the problem may be in the sprin-operated valve in the tank itself. But every now and then, after filling the tank at the sink and replacing it (firmly) into the machine, the water starts dribbling out down the side until the tank is empty and the counter is aswim. The local repairman wants $125 to "overhaul" the Magic, but everything works fine except for this now-and-again leak. Any help?
  • arcalim Feb 27, 2009
    exact same problem.
    Problem Solver:
  • 4 Answers
I have a Saeco Magic Deluxe that does/did the same. The water tank, when filled would empty down the side of the machine and all over the counter top.
I recognized that the lid on the water tank, when pressed firmly in place, created a back-pressure because air was not able to get into it and level out the pressure. I've resolved this problem by leaving the lid slightly ajar allowing air to circulate into the water tank itself. I've also thought about drilling a tiny hole into the lid itself but have not done that yet for I don't want to comprimise the plastic.
Peter (Detroit, MI)
Posted on Mar 01, 2009
My saeco magic plus leaks water when the tank is full
You should check the water tank gasket which is located directly under the water tank.. It is not part of the tank. It's on the machine side.
See the video on our page.
http://www.cerinicoffee.com/saeco-water-tank-gasket.html
Aug 28, 2013 | Miele CVA615 Espresso Machine
Our 7 year old Saeco Magic Delux has started to leak water when we fill the tank. It runs out of the bottom of the tank and down the side. Happens about 20% of the time. Is it worth having a 7 year old one...
If I understand well the problem is only with tanks valve which means the spring have become more soft and stays a litle open so you have water leak. It maybe because some scale or dirt keep it open some time.
In order to decide if it wise to fix it or not the answer is simple if you have a good coffee result in cup which means that the grinder grinds good, presure pump work good and boiler heat up ok then you will only need to complete descale the machine and replace only small cheap parts and you will have a very good machine again for some more years. Remember a brand new machine will do the same espresso like yours.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Magic De Luxe Espresso Machine
Water container leaking on Saeco Magic coffee machine
Hi
There is a donut like cap under the water tank on top of the machine. Pry on the outside of this cap an pop it off. Under the cap is a black seal. If you stick your finger in it and just pull out and the seal comes with it, you need to replace the seal. The new seal will not slip in you have to run your fingernail around the outside and silp the seal in. It should not just slide in. Make sure that the receptacle is clean before putting the new seal in.
Apr 28, 2009 | Saeco Magic De Luxe Espresso Machine
Water leak between tank and main unit
Hi
If it is leaking on top of the machine and under the water tank, there is a seal that needs to be replaced. Lift off the water tank. There is a large gray doughnut cap that will pop off. Take a screw driver and slip it under the outside of the cap between the machines top and pry gently up and it will pop that side. Go to the other side and do the same. Set the cap aside and take you index finger and stick it in the center of the black gasket. Lift up and if the gasket comes out with it you need to replace it. Clean the inside of the receptacle before installing the new gasket.
Once you get the new gasket, slip it at a slight angle(flat side up), then take your finger nail and run it around the outside edge of the gasket. It will slip in, then push it down. Take the cover and snap it into place. Your good to go.
Mar 24, 2009 | Solis SCDIG-5000 Coffee Maker, Espresso...
Water leaking under the tank
If the water is coming from under the cold water tank on the back of the machine it probably the o-ring seal in the grey machine recepticle which is visable when you remove the tank for filling. This seals the tank to the machine body and over time can leak (mine has!!). You can get them from Gaggia UK in Halifax
Dec 24, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Jun 26, 2008 | Saeco Vienna De Luxe Espresso Machine
Water tank stay's on
2 things. Water tank has a magnet in it (little rectangle black plastic piece on the backside). Thats gone bad. need a new water tank.
2nd is you need a water tank gasket.
Gasket is easy to fix, flathead screwdriver.
May 13, 2008 | Saeco Magic De Luxe Espresso Machine
Filter in saeco magic delux
little magnet keeps that red light from coming on.
magnets probably gone bad, need to buy a new water tank. As far as i know saeco does not sell the magnets seperate.
could also be a blockage sending the machine into alarm.
May 08, 2008 | Saeco Magic De Luxe Espresso Machine
Central unit light on a Magic delux is on Saeco
My water tank light stay's on ( can't make espresso) plus water seem's to be leaking out into tray area, also can you tell me where the filter is, and how to get to it? Helpppppppppppp!
Apr 28, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
155 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
