Question about Cobra 29 LTD CB Radio
Trying to wire up a atatic echo board in a cobra
Trying to wire up a astatic echo board in a cobra 29 which pin on the mic do you hook up to
Take the mic plug apart and look at it the wire with the shield around it is the audio, then look and see which pin it hooks to.
Posted on Mar 05, 2009
Pin mic wiring
1- Audio
2- Shield
3- Relay-for RX
4- Transmit
Oct 05, 2013 | Cobra 29 LTD CB Radio
How do you wire atrb-x2 echo board in a cobra 29 cb i was told the white wire inside the radio is the audio wire mine does not have awhite wire on the mic con. on the inside
don't worry about wire colors. pin 1 is ground. some mic's need two wires for ground depending on the PTT switch used. pin 2 audio. pin 3 TX pin 4 RX.. thats all there is too it. once you know the pins all radios are easy. galaxy/connex/genlee same pin outs except pin4 isnt' needed for RX but can be used for 9v dc to power micropohnes.
Nov 26, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Feedback problems with astatic echo boards
This is a classic indication of a lost shield or ground connection in the mic circuitry. Double check these connections for good contact in the mic *and* the plug at the other end of the cable.
Check the grounding and SWR or "match"of the antenna system, too. A poor SWR (greater than 1.5:1 or 2.0:1) can cause the reflection of RF back to the radio. Modifications can increase sensitivity of the mic to this unwanted RF.
Sep 29, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
I have a deisel 4-7 echo mic ineedcolor to pin to wire it to a Cobra 29 ltd classic thank you so much
cobra:black--ground
yellow--mic
red--tx
blue--rx
the wiring for the echo mic is identical
Sep 16, 2009 | Radio Communications
Installing an Astatic Echo Board in a Cobra 148
There should have been instructions that came with your reverb board. You are going to need to drill another hole in the case of the radio, or find a control where you can install a dual control knob onto.
Your reverb board is likely going to need 8v, so you will need to locate that off the logic board, likely from the frequency synthesizer. The the audio lines from the mic, or the output of mic amp, are going to be redirected to the reverb, and the output of the reverb feed back to where the wires were removed from.
If I recall correctly, the 148 is a bit of a bear to work with, not much room inside. You will likely have to get creative in placement of the reverb board itself. Make sure to wrap well so that it doesn't get tossed around and break something inside.
Sep 15, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Looking to install astatic echo board in uniden PC78XL
usally on most radios you will unplug the wire that comes from the number two mic plug. you will hook you sheid witch is the 2 little black wires from the echo board to number one mic plug. then the two wires will go to wire you unplug and the other one will go to number 2 mic plug.
Jul 04, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
How to wire a power echo mic up theres 5 wires and 4 oins
I suggest buying a 5 pin to 4 pin adapter. Ebay has them for $6. I would go chopping wires on the mic. Cobra 29 ltd is a nice radio. Have one myself.
Apr 25, 2009 | Cobra 29 LTD CB Radio
Trying to hook up a astatic echo board
Looking at the plug from inside the radio, with the nub facing downward, from right to left you have pin1 pin2 pin3 and pin4.
1-Shield
2-Audio
3-Transmit
4-Receive
Colors are
1- Red
2-White
3-Blue
4-Black
Mar 24, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
304 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
