Question about Avanti WC492D Wine Cooler
Avanti WC492D wine cooler temperature control does not work
My temperature is set at 64 degrees, but the LED readout is saying 73 degrees and the wine feels like it's 73 degrees. This has haapened in the past and just by moving the unit around a little makes it work again. What is causing this intermittent problem? Low refrigerant? Loose wire? Please help my precious bottles of wine.
  • Anonymous Mar 26, 2014
    temperatures won't get lower than 73
    Problem Solver:
  • 19 Answers
The wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Posted on Feb 21, 2009
I have a Avanti wc492d wine cooler that is not working. The unit shows power(lights are working) but it will not cool at all. I can here a click sound when I change the temp set, but the cooler will not...
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Jan 28, 2011 | Avanti WC492D Wine Cooler
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
My Avanti wine cooler is not cooling any more.
piece of junk, can not be fixed. Join all the other ones who have bought this unit.
Aug 01, 2009 | Avanti WC3201D Wine Cooler
The Wine Cooler Won't cool, the internal thermostat reads 39 degrees, but the actual inside temp is close to 70 degrees. The unit is set at 59 degrees! Sometimes I can unplug it, the plug it back in and...
Order a new control board if it is working after you unplug it it's because the control board is being reset. You can contact the manufacturer and purchase a control board directly from them .
Feb 02, 2018 | Avanti WC5100BG Wine Cooler
How do I reset the digital conroller on an Avanti WC3201D?
Press and hold both temperature controls until it beeps. It will reset to 50 degrees.
Jul 02, 2009 | Avanti WC3201D Wine Cooler
Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Mar 02, 2009 | Avanti Refrigerators
Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 30, 2008 | Haier BC112G Wine Cooler
How to reset the temperature on the danby silhouette wine refrigerator
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Jun 03, 2008 | Danby DWC283BLS Wine Cooler
Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Dec 31, 2007 | Avanti EWC28 Wine Cooler
Avanti WC492D Wine Cooler Logo
960 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
