Question about Seagate Momentus 5400.3 Hard Drive
I have a seagate momentus 5400.3 160gb drive installed in a Thinkpad t60 laptop. It was working fine until after I had put it in hibernation, and subsequently tried to get back in (approximately 2 hours passed between the first action and the second). When I tried to get in, the system went to a blue screen stating that there was (I think), an unrecognized boot volume error. I have now put the drive in an external USB drive. Although explorer can identify the drive, when I try to look at the contents of the drive, the system states "the request cannot be performed because of an I/O device error". Is there a way to get access to the data?
Configuring the BIOS
After completing the drive installation, restart your computer. Your computer
may automatically detect your new drive. If your computer does not
automatically detect your new drive, follow the steps below.
1. Restart your computer. While the computer restarts, run the system
setup program (sometimes called BIOS or CMOS setup). This is usually
done by pressing a special key, such as DELETE, ESC, or F1 during
the startup process.
2. Within the system setup program, instruct the system to auto detect
your new drive.
3. Save the settings and exit the setup program.
When your computer restarts, it should recognize your new drive.
That should work ya long haired hippie. give me a shout this weekend, M.Y. (puff puff pass *****!)
Posted on Apr 16, 2009
Added a ST95005620AS in Lenovo (2503) docking station as a second drive and it is causing a slow boot in Lenovo T60
Very strange, I added a WD 500GB in place of my CD drive in my R60 and have had no issues. I suggest the following:
1. Pull the Seagate drive from the docking station, does the laptop boot faster (confirm the added drive is really the problem).
2. Put the drive caddy back in with a drive with one of another brand other than the Seagate, see if the performance imorives (confirm its the Seagate which is the problem and not the caddy or docking station).
If performance increases in both cases, do some research on compatibility issues between the IBM and Seagate drives. I would also go to Lenovo's website and update the laptop BIOS... this can easily be accomplished by downloading a tool and doing it through Windows. I had issues with using a non-Lenovo battery with my R60 till I updated the BIOS. Good luck, let me know if you get to the bottom of this. Please rate me if this helps you. Thanks.
Jan 04, 2012 | IBM Lenovo ThinkPad T60
Seagate external drive Momentus 5400.3 is not recognized in my Win 7 laptop.
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 08, 2011 | Seagate Momentus 5400.3 Hard Drive
I have a HP Pavilion dV5t-1000 laptop with a Momentus 5400.4 hard drive. All was working fine until today. The computer is now telling me the hard drive does not exist. I connected it to my custom built...
No, the disk doesn't appears in My Computer because the file system on it is completely corrupted - all the data is lost. To see if the hard disk itself is recoverable download, install and run this free program (select the correct disk for testing)
http://www.hdtune.com/files/hdtune_255.exe
Feb 03, 2011 | Seagate Momentus 5400.4 250GB SATA/300...
Hi There. I am looking for an Internal Hard Drive to suit a Dell Inspiron 1525 Laptop. Seagate Momentus 5400.3 160Gb ST9160821AS. Where can I get one or is there another Hard Drive that would be OK to use...
I suggest you check the specification of your Dell laptop to see the maximum size hard drive it can support. The maximum size hard disk you can install in the laptop depends upon the BIOS.
Any major brand of 2 1/2" hard drive will work with the Dell.
Oct 27, 2010 | Seagate Momentus 5400.3 - 40GB - 5400rpm -...
I have a Thinkpad t60. For the past few days it won't go into hiberation when I close the lid. It just stays on and consumes the battery.
I have seen this issue before with my T60. It seemed to be related to not having restarted my laptop in a while. I used to use hibernate rather than shutting down my laptop for weeks at a time. Actually restarting my laptop seemed to get hibernate to work again.
In addition, you can check to see if for some reason the hibernate option has been disabled.
In Win XP (Win 7 is very similar):
  1. Click Start and select Control Panel.
  2. Double-click Power Options.
  3. On the Hibernate Tab, ensure Enable hibernation is selected (check mark).
  4. On the Advanced Tab, ensure that the setting for When I close the Lid is set to Hibernate (select it from the drop-down list if necessary). There should be an option for when plugged in and when on battery. Set both to your preference.
Hope this helps. Thanks for using FixYa.com
Jan 18, 2010 | Lenovo Thinkpad T60 Notebook
Thinkpad X 200
It came with a 7200RPM 160GB SeaGate Momentus (ST9160823AS) SATA. As long as the hard drive is an SATA drive it will work on your system. The drive has the details on it.
Dec 05, 2009 | Computers & Internet
Whats the biggest ram I can put in my HP G7000 note book to replace ST9120822AS which is currently in my machine.
Currently the largest drives for notebooks are are
Hitachi Travelstar 5K500 500GB
Seagate ST9500420AS Momentus 7200.4 500GB
Seagate ST9500420ASG Momentus 7200.4 500GB
Seagate ST9500325AS Momentus 5400.6 500GB
Samsung Spinpoint M7 500GB
Samsung SpinPoint M6 500GB
Nov 13, 2009 | Seagate Momentus 5400.3 ST9120822AS 120 GB...
I have a seagte momentus hard drive, need master password
you will haveto ask seagate forthat information
Oct 07, 2009 | Acer Aspire 5100 Notebook
I need the driver for your momentus 5400.2 hard drive
U have install all drivers properly in ur hard drive it can be work properly
Jul 11, 2009 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
Seagate Momentus 5400.3 Hard Drive Logo
363 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
