Question about JVC BR-DV600U Mini DV VCR
JVC BR-DV600U Mini DV tape deck eats tapes
Tape deck seems to function okay, except when I put in a tape cassette, the deck doesn't release the tape, and ends up ruining it. The eject button works to eject the cassette, but the tape stays caught up inside.
  • 221 Answers
SOURCE: Won't properly accept tapes/ tape won't fully insert
probably a bent cassette housing in the deck - time to seek out jvc authorized repair.
Posted on Jul 02, 2008
mistersony
  • 320 Answers
SOURCE: JVC BR-DV3000 Mini DV-DVCAM issue
If the problem only shows with Mini DV tapes, it can be a tape guide issue or a mchanism loading problem where the tape is not being properly "seated" into the tape mechanism. You will need to use an oscilloscope to look at the RF waveform coming off the tape to try and figure out where your problem is.
Posted on Nov 08, 2008
MNfisherman
  • 11896 Answers
SOURCE: Will not release the cassette when ejected and breaks the tape.
there is a spring attached to the tape release gear that will eventuall wear out through time, also, sometimes the rubber belts wear out and throws the timing off.
That would be the first two things to check. Make sure spring is not stretched. Try testing with cover off and watch to see if the part holding the back of the tape releases.
Posted on Mar 11, 2009
  • 6 Answers
SOURCE: mini-DV tape deck eats tapes
internal misalignment causes the tape to mount incorrectly, grabbing and eating the tape. must find a repair facility to realign. do not attempt yourself as the internal mechanisms are so delicate it is easy to cause another problem
Posted on Oct 22, 2009
Testimonial: "Really appreciate that, now that I know it isn't just dirty tape guides I will try and find someone who kows what they are doing. "
SOURCE: I purchased a JVC BR-DV600U DV deck to use with my
There exist a number of methods for dealing with FireWire device interference, a few of which are explored here. Switching Ports The first procedure you should try when experiencing a problem that you believe to be caused by device interference is to simply reconfigure the arrangement in which your FireWire peripherals are connected. Try switching each device to a different port, or temporarily disconnecting one or more of the devices. In particular, if you are a PowerMac G5 owner, trying switching devices from the front to back ports or vice versa. Adding an external hub In some cases, it appears that FireWire devices are not drawing enough power from the computer. This can cause a sundry of strange issues, including apparent conflicts between devices and unexpected power-offs during device operation. In these instances, adding an externally powered FireWire hub can clear things up. One of the reasons an "under-powered" situation can occur is that different Mac models have varying power capacities available through their FireWire ports. PowerBooks and iBooks have the least, generating around 7 watts. The iMac G5 also generates a relatively low amount of FireWire power, sharing 8 watts between its two FireWire 400 ports. The Power Mac G5 shares 15 watts between its one FireWire 800 port and two FireWire 400 ports. Place devices on different FireWire busses/Isolate the iSight Similar to the above procedure, adding another FireWire bridge -- via an extra PCI-based FireWire adapter or another means -- can eliminate conflicts from devices that reside on the same bridge. Power cycling the system Simply cycling the power on your system may be enough to temporarily eliminate a few FireWire conflict issues. Shut down your Mac, and disconnect all FireWire devices as well as the computer's power cord. Leave the system off for about 10 minutes, then plug it back in. First turn your Mac back on, then re-attach the FireWire devices one at a time and check for the conflict to resurface. Disconnect specific FireWire devices (especially iSight) to check for conflicts As noted above, the most common cause of interference is Apple's own iSight. In case after case, simply disconnecting this single device has eliminated problems with other FireWire devices. Other devices often implicated in FireWire conflicts include video-related devices; cameras, the EyeTV, video decks, etc.
Disconnecting the iSight has proved particularly successful for an issue where the iPod disappears from the Desktop and from the iTunes playlist, while the iPod status screen cycles from the Apple logo to a "Do not Disconnect" message over and over. The exact reasons why the iSight causes more than its fair share conflicts with other FireWire devices are many, and sometimes unclear. One potential source of conflict, however, could be the unit's high bandwidth usage. The iSight captures video at a 640 x 480 pixel resolution, at 30 frames per second in millions of colors. Such throughput uses a significant chunk of the standard FireWire port's 400 Mbps bandwidth. As such, when other devices are connected, the bandwidth requirements for satisfactory performance may not be met. Try disconnecting all FireWire devices, then adding them back one by one and repeating the originally failed operation to check for conflicts. Apply the latest updates Make sure that your FireWire drives are using the latest firmware (check the manufacturers' Web site) and the most recent iPod update has also been applied. Of higher importance, if you have an iSight, is the iSight 1.0.2 updater. In a large number of cases it has resolved conflicts caused by the camera. Re-apply the most recent Mac OS X combo updater In some cases, re-applying the most recent combo updater can resurrect seemingly defunct FireWire ports and allow devices -- drives included -- to be recognized again. The most recent combo updater is available from Apple's download page. Clear caches Try using a tool like Tiger Cache Cleaner or Cocktail to remove potentially corrupt system caches. Restart, then check if your FireWire devices are recognized.
Posted on Feb 05, 2010
My JVC HR-DVS3u Mini DV recorder deck keep displaying use cleaning tape, I use the jvc cleaning tape and it still ask for it.
my JVC HR-DVS3u Mini DV recorder deck keep displaying use cleaning tape, I use the jvc cleaning tape and it still ask for it.
Dec 24, 2009 | JVC HR-DVS3 Mini DV/S-VHS VCR
Mini-DV tape deck eats tapes
Oct 05, 2009 | JVC SR-VS20 Mini DV/S-VHS VCR
Aug 22, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Samsung VP-D103i Mini DV eating tape apon inserting
Have you cleaned the tape deck using a DV tape cleaner?
Jul 06, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Jun 12, 2008 | JVC BR-DV3000U DV/Mini DV VCR
MiniDV tape stuck inside
sounds like a defective cassette housing, but i have seen problems with jvc decks and camera when tdk or maxell tapes were used. the lids on these tapes seem to get stuck in the cassette housings in jvc equipment. jvc even recommends that tdk and maxell tapes be avoided.
May 24, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Samsung sc-d353 Eats Tapes
THIS NEEDS A NEW CASSETTE COMPARTMENT. SAMSUNG IS REALLY EXPENSIVE. YOU MIGHT TRY TO PURCHASE A USED ONE OR I MIGHT BE ABLE TO HELP YOU WITH PARTS
Nov 18, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
VTR won't play
I would take a look at the loading machanism to see if it is properly loading the tape, usually on these type of machines if the tape is not being loaded properly the tape will not play. The rewind working indicates that the motor is still working so what you may also have is a gear problem, in which you will have to look at the gear system as the tape is loading and trying to go into play mode. This looks more like a mechanical problem then an electronics issue. However I would not rule out have to take voltage measurements to confirm that the electronics are ok (you will need a schematic for this, and a multimeter).
Sep 13, 2007 | JVC BR-DV600U Mini DV VCR
JVC GR-D370 Mini DV Digital Camcorder
Usually when the recording is started it takes around 10 to 15 seconds for the camera to recognise and display the duration of remaining tape, if you feel there is a problem, try using different brand tape.
Mar 17, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Tapes not in 24p play for 2 seconds than stop, WHY?
The BR-DV3000 DV deck has LP inhibit function which is set in the operations menu. JVC does not recommend the use of LP mode and therefore locks this mode out by default. You can change this setting to allow operation in LP mode if you like but I don't recommend it. Using LP mode on DV tape causes the error rate to escalate due to the narrower track width produced by the slow moving tape. Good Luck, this is a nice machine! Joe Weibel Custom Electronics (customelectronics.org)
Feb 13, 2007 | JVC BR-DV3000U DV/Mini DV VCR
JVC BR-DV600U Mini DV VCR Logo
90 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
