Question about Akai LCT2715 27 in. LCD Television
Fuzzy black & white picture connecting a Wii to AV input
The Wii will produce color screen on another TV.
Am I missing certain settings, or, is the AV input faulty?
  • Chuck May 11, 2010
    Make sure you are using the correct input on tv. Hit input on remote until you see a picture. What kind of cable are you using? composite component?
  • 53 Answers
SOURCE: Aquos LC46D64U, problems with av input video signal
You know, I've had two repair instances regarding this particular model line (D64U) where there were problems with only the analog inputs (such as the component/composite).... but with no problem with the HDMI inputs.
Replacing the Main Board fixed these TV's. Since both the Xbox and the Wii present the same problem on two separate inputs, this leads me to believe you most likely have a defective Main Board. If your TV is still under warranty, I suggest calling Sharp to locate your local authorized service center.
Posted on Mar 18, 2008
  • 8 Answers
SOURCE: poor picture quality in new Akai plasma TV
Try putting a fan on the back of the tv to see if it is getting better. If it does then you probally have a board that is overheating. If that is the case then CAREFULLY !!! remove the back and place where you can turn on and safely access the open back NO TOUCHING STUFF !!! Mabey lay it face down on a glass table or lay it on a table with 25% hanging over the edge to see the screen. Then take a COLD blow dryer and blow it on the boards to find out which one makes it get better. If one does then it will probally be your problem board. Make extremely sure that is the one before removing it by blowing from all angles on the boards around it without air hitting the suposed problem board. Then try a little hot air to see if that starts the problem on that board so you can be sure. Of course check the surrounding and offending board several times to be sure before removing.
Posted on Jul 12, 2008
SOURCE: I bougth a lcd samsung 40 inch tv. I cannot connect my gamecube
You need to get a special scart lead which you can connect your red, white and yellow leads to then connect the scart lead to your tv it should work then
Posted on Feb 01, 2009
banjaxter
  • 5 Answers
SOURCE: Connecting any outside devices (Wii, DVD player)
Have you tried another cable or checked to see if the existing one is pushed fully in? This can sometimes be the cause of what you've described.
Posted on Jan 25, 2010
budmrtn
  • 11361 Answers
SOURCE: Picture gets fuzzy then screen goes black-still has sound
It can be the T-CON board is over heated and goes out, it can also be the main board, you should try cooling the T-CON board when the picture gose out with electronic freeze spray for electronics troubleshooting to see if the picture will come back, need to narrow down the problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 19, 2010
My wii when i turn it on it only has lines going across the screen.. about a week back it was saying something about the memory. now it wont load the wii menu nor will it load any games... if anyone knows...
Picture Is Black and White or Does Not Appear
Situation:
The console powers on and shows a black and white image on the television screen
The console powers on and there is no image on the television
What to do:
Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
AV Cables
Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
Try another set of inputs on the TV, or hooking the Wii console up to another TV.
If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
Component Cables
Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Was this information helpful?
Nov 02, 2012 | Nintendo Wii Console
Wii in black and white
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Apr 17, 2012 | Nintendo Wii Console
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
What to do:
  • AV Cables
  • Component Cables
Still Not Resolved:
Mar 06, 2012 | Nintendo Wii Console
Trying to hook up a dvd and wii with direct tv and can"t get sound out of wii! HELP Can you show me where to plug cords in?
Your TV has two sets of AV inputs. One on the side and one at the back. The Wii has a 3RCA cable ( Yellow / Red & White ) . Connect these jacks to the corresponding color sockets on the side input of your TV. Select that input on the TV and your Wii sound and picture should come on.
For the DVD player you have to get a 5 RCA component cable. This cable will have 5 colored jacks, connect the White & Red to the Audio in of the TV and then connect the Red/Blue/Green jacks to the component video input of the TV.Do the same at the DVD's end also. Setect that source on the TV and you should hear the DVD sound and picture.bobhifi_31.jpg
Apr 03, 2011 | RCA L32HD41 LCD TV
My wii and Netflex is in black and white.
Access your TV's menu screen:
- be sure that your TV screen is expecting input from "AV" or "Video" - if you have the "S-Video" input setting selected, change it to "AV" or "Video"
This should bring the color back to your Wii experience.
Jan 24, 2011 | Nintendo Wii Console
Wii powers up doesnt have a picture or sound tv screen.
    • With the yellow, white, and red AV cables that came with your system:
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs? If so,click here for complete information on doing this type of hook up.
      • If this is your first time hooking up the Wii console or have you moved it to another TV, please click here to review our step-by-step connection guide. Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
    • With the blue, green, white, and red component cables (sold separately):
      • Review our step-by-step Wii Component Cable connection guide to make sure the cables are properly inserted and that your TV is set to the proper input.
    If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
Dec 29, 2010 | Nintendo Wii Console
I plugged our wii into new tv. the screen shows a black and white picture. how do i fix it?
    What to do will depend on how you're connecting your Wii console to your TV.
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs... if this is your first time hooking up the Wii console or have you moved it to another TV, . Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
      • Review our step-by-step Wii Component Cable to make sure the cables are properly inserted and that your TV is set to the proper input.
Dec 26, 2010 | Nintendo Wii Console
Having just installed a new Wii console I have good sound but everything is in fuzzy black and white - no colour at all. What should I do to get colour?
      • If this is your first time hooking up the Wii console or have you moved it to another TV, Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
The wii is only showing in black and white. how do i get a color screen?
Change the settings on the tv so that the input is in the "AV" format. Press the AV button twice and it will go into color
Dec 26, 2009 | Nintendo Wii Console
Wii Start but the game didn't start, screen went black
  • Is this your first time hooking up the Wii console or have you moved it to another TV or VCR?
  • The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
    • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
    • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
    • Look for inputs marked Audio and Video IN.
    • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
    • Do NOT connect your system to anything marked OUT.
  • My experience shows that the majority of these issues can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
  • If you have verified the connection is correct, and are still receiving a blank white or blank dark screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired.
Jul 11, 2008 | Nintendo Wii Console
Akai LCT2715 27 in. LCD Television Logo
302 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
