Question about Canon PIXMA iP1800 InkJet Photo Printer
Error 5001 on canon ip1800
Hi there, I just installed the cannon ip 1800 on my laptop and I have fallowed all required steps but I'm getting error 5001. how can I solve this? I'm using windows vista.
  • Anonymous Mar 17, 2014
    error 5001
  • 2,404 Answers
Hi there, service error 5100 is a carriage home position error.
Turn off and unplug the printer from the power supply.
Remove any paper.
Buy a can of compressed air from an electronics shop or computer store. Use the compressed air (Not a vacuum!!!) to blast out any dust bunnies, paper particles and debris. (Don't do this with the cartridges removed as you're likely to fill the printhead with air!!)
Use isopropyl alcohol and a cotton swab (Qtip) to clean the plastic strip that runs the length of the guide rail (the metal rail that the cartridge carriage moves along), it may be contaminated with ink and debris.
Remove and reinsert the ink cartridges inside the cartridge carriage to ensure that they're connecting properly.
With the power off, carefully slide the print head (carriage) to the center of the guide rail. You should not have to force it! (There will be some light resistance but it should move quite easily by gently pushing on it with your finger.)
Close all the access doors, plug it back in, connect your USB cable and turn on the power.
As it runs through the initialization, the printer should sense that the carriage is out of position and automatically move it back to where it should be.
Hope this helps solve your problem, I've had other people do it and its worked for them.
Posted on Feb 21, 2009
How to fix service error on canon ip1800
You will need a resetter. Download this software and follow these steps.
Step 1: Reset hardware
  1. Press Resume button hold for 1 – 2 minutes
  2. Open the cover
  3. Release the catridge and then put catridge again
  4. Close The Cover
  5. Turn Off
  6. then Turn On again
Step 2: Reset Software using general tools
  • Download software resetter or general tools for canon pixma iP1800 http://www.mediafire.com/?nmfns4hixel :Driver should have been install correcly.
  • Connect USB cable.
  • Before connect power, press and hold power button then connect the power.
  • At the same time Hold power button, and press reject button for 2 times then release power button.
  • Run software resetter for canon iP1880.
  • Don’t forget to open lock release in the software. ( note : to view locK release menu, min resolution 1024 x 728)
  • Then select Set Destination to iP1880
  • Check CLEANING and EEPROM CLEAR
  • Click MAIN and PLATEN
  • Finally test print by click TEST PATTERN1.
Mar 18, 2010 | Office Equipment & Supplies
How can i solve the problem error 5001 of ip 1800 canon
5001 is not an error code but 5100 says that there is a paper scrap blocking the carriage, or grease on the encoder strip. The plastic strip behind the carriage assembly that runs all the way across the printer. Try first to clean the strip with a damp Q-tip just damp with water.
Jul 27, 2009 | Canon PIXMA iP1800 Printer
How can i install the canon pixma ip 1800 without disk?
Go to this web page:
IP1800 Support
If the "Drivers & Downloads" tab is not selected, select it.
Enter your operating system in the drop-down menu.
Drivers and additional software links will be displayed. Click on the file name to download them.
Save the file to your computer. (Desktop is easiest if you are not familiar with placing the files in a folder.)
You can then install the driver/software from your computer.
Thanks for using Fixya.
May 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How to correct error 5100 in canon pixima ip 1800 prnter
Hi You can Try
If you still look at this web then have a go
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Sep 27, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Adding printer pixma ip1800
Hi there mosse_123
This happens a lot, you're going to be fine. The following links will get you up and running. I've included both Windows and Mac procedures. Use the ones that are applicable.
Click here to download iP1800 drivers.
  • Read the procedure.
  • Click the link in Option 1.
  • Question 1 = Printers
  • Question 2 = PIXMA iP series
  • Question 3 = PIXMA iP1800
  • Click GO
  • Select your Operating System and follow the prompts.
Click here for the iP1800 Windows install procedure.
Click here for the iP1800 Mac install procedure.
If you have any problems let me know. We'll get you up and running
Remember: good things happen to those who Rate.
Mike
Jul 21, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
583 people viewed this question
old marine
old marine
