Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE side by Side - dead, again
GE Side by Side - died 2 months ago. No cooling, but the fans worked, and compressor relay looked ok - recommendation was to replace the motherboard, which I did. There was clearly a burnt out circuit. It worked great for another 5 weeks. Now it is completely dead again.
Lights are on - so it has power.
Fans are NOT turning on (neither back nor inside)
Compressor is not even attempting to turn on - no clicking or anything.
Not a defrost problem - tried a full 24 hr unplug and re-plug - didn't help.
No visually obvious issues on the motherboard this time.
Thoughts? I'm about to order a new fridge. 6 yr old, out of warranty.
  • Anonymous Apr 23, 2009
    I have the same problem with my defrost timer. How long do you need to leave the timer off?
  • dhilb May 11, 2010
    where is that located? GSH25KGMBB
Check defrost timer . plug in and turn timer manualy and see if unit starts running. This means it was in a defrost mode which occurs twice daily.
Posted on Feb 21, 2009
About 36 hours ago our Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25CQXFW02 was not cooling (frozen was thawing, and refrigerator was not cold) the compressor and fan were running, I cleaned the...
depending on your model. if its just a reg, side by side, you more than likely need a relay/ overload which is located on the compressor,the relay only works after it cools down. unplug ref from wall, remove rear cover to see and touch compressor to see if it starts when you plug back in to the wall. if it doesnt start in three attempts. replace it. easy way to diagnose..
Jan 17, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
My side by side fridge has stopped chilling down, the power is Ok, and moter seems to be working, but no cold inside. A few months ago the freezer side stopped, but as i did not use it , i just left well...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS25KGMB CC side by side GE fridge not cool.
You should check first to see if the condenser coil is dirty ( condenser coil is the Fin type coil you see in front of the compressor ) You can clean this by just brushing it out with a brush .The relay is plugged directly onto the compressor
May 17, 2017 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
The main control board is going bad . This is the electronic board behind the 8 x 10 inch panel , on the back of the refrig . Your relay on the compressor is ok .
Feb 20, 2010 | GE Refrigerators
My frigidaire side by side quit cooling about two months ago i un pluged it cleand everything and let it sit for about 3 days pluged it back in and it worked for almost 2 months now it is not cooling again...
there sunds to me like there is a problem with you defrost ever how need to look for any ice build up in the bottom side of the freezer section.
while the unit is the cooling mode open the freezer door and listen for a fan running if you do not hear a fan running you may need to replace it the door switch should be held in while you are checking this.
then i would alos look at the overload relay and start switch on the compressor.
Jan 31, 2010 | Frigidaire FRS26R4A Side by Side...
My GE side-by-side refrigerator & freezer is not cooling.
Good day,
If it's been on for a while, the compressor should be warm. If the compressor has a relay box mounted on it's side, remove the cover, and pull off the relay, and overload and take them to an appliance parts house to be tested. If defective replace. If O.K. then .....
The compressor windings are out and the compressor is bad, or the motherboard on the back rear of the machine under a cover has failed.
Either case requires a service tech to properly test.
Jan 19, 2010 | GE GSS25LSMBS Side by Side Refrigerator
Fridge is not cold and freezer is not cold
f the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jan 10, 2009 | Maytag MSD2454G Side by Side Refrigerator
Refridge not cooling
hi thanks for the question . yes look at the compressor the start relay is burnt out replace it that should solve the problem thanks the appliance doc
May 31, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Dec 02, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
