Question about Kenmore Washing Machines
My kenmore top loading washer does not always spin my clothes fast enough to get the water out even in small loads
  • 15,935 Answers
SThere is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Kenmore Special Edition Top Load Washer - model # 24692300 - clothes are still quite wet following spin cycles. Machine appears to spin at a reasonable speed. HELP!!.... Thanks
Hi, Could be as simple as a slipping belt, they can get glazed, stretch or even get wet small water leak, and get the tub spinning but not fast enough or taking to much time getting going fast that the washer timer says it should be done and goes into the next mode. If you have no Idea how to repair the belt or check by looking under the machine after you unplug it, the only help is the repair person.
Nov 23, 2011 | Washing Machines
Spin is not fast enough for bath mat even with other items in washer. How do you activate spin indepedently?
Hello, Welcome to FixYa. I think what you're referring to..."tub mat will not spin fast enough to dry"... is not an intended function of the washer. I don't know if you purchased these machines yourself or have access to the owners manual/operation guide, but if you do you can verify what I'm telling you. Front load washers ( any washers really, but top loads are a little more forgiving ) are not intended to wash bath mat's or any single items. If washing a single item one must either select a "no spin" or add another garmet/item of equal size or mass to balance the weight of the load, otherwise the unit will not spin to it's potential...if at all. This is an exert from the Kenmore/Whirlpool operating manual... 1. To load washer Open the washer door by pulling on the handle. Sort laundry according to color and type of fabric. Place a load of sorted clothes in the washer. Do not overload washer. Overloading can cause poor cleaning. The washer can be fully loaded, but not tightly packed. Washer door should close easily. Mix large and small items. Avoid washing a single item. Load evenly. Wash small items such as infant socks in mesh garment bags. It is recommended that more than one garment bag be used and that each garment bag be filled with equal amounts of material. Hope this info helps clear this up for you. Let me know how that works, but that should fix the problem. Good luck. Thank you for choosing FixYa to day for your inquiry. Regards, Macmarkus :)
Mar 04, 2011 | Kenmore HE2 Plus Front Load Washer
Washer spin cycle won't spin enough water out of clothes in large load, but will still spin small load.
This sounds like you have a bad clutch if it's a direct drive top load. ...have to pull the motor, drop transmission, and replace.
Western Appliance Repair
Washer Repair Meridian
Oct 02, 2010 | Kenmore Washing Machines
Kenmore washer want spin out allthe water buy a new water pump
If it is pumping out some of the water then the pump is probably okay and the problem is probably in the clutch or belt slipping not spinning the clothes fast enough.
Mar 05, 2010 | Kenmore 22422 Top Load Washer
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Kenmore washer spin cycle doesn't leave clothes dry
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Open Questions:
Washing Machines Logo
63 people viewed this question
Sal De
 Brian Main
Brian Main
