Question about 1995-1997 Chevy Tahoe Ignition Starter Alarm Switch
Fuel Pump not working
1997 Chevy Tahoe LT 5.7L V8
I have a malfunctioning internal fuel pump. How would I go about accessing/changing it, and do you have any suggestions on a quality brand that is in an affordable (CHEAP) price range!!! I have looked at a Delphi on autopartswarehouse.com
Also, would it be feasible to change to an inline setup? If yes, what steps do I need to be aware of? (ie. do I need to remove the old fuel pump anyway...)
Any help would be appreciated!
Brad
You should seriously make sure sure that your fuel pump relay in the fuse block under the hood is not bad first before you go through ALL that. I have had one go bad and months later get a bad connection and not turn on cause I don't have the cover for it and **** gets in there. Not sure about the inline I have always wanted to try that.
Posted on May 03, 2009
1997 chevy tahoe not running
Check for spark check coil check ignition module
Aug 31, 2012 | Chevrolet Tahoe Cars & Trucks
Chevy tahoe would not start because we change out the fuel pump with a brand new fuel pump. We connected the fuel pump proper according to detail diagram provide by the factory. The vehicle is a 1997 tahoe...
DID YOU GET A GM PUMP OR A CHEEP AIRTEC PUMP,DID YOU HAVE TO SPLICE THE NEW WIRES THEY GIVE YOU,IF SO MAYBE ONE DIDNT GET CRIMPED WELL ENOUGH.ALSO CHECK FUEL PUMP RELAY UNDER HOOD.MAYBE SWITCH IT AROUND WITH ANOTHER ONE.IF YOU CAN REACH THE PLUG FOR THE FUEL PUMP GET A TEST LIGHT AND SEE IF YOU HAVE POWER TO IT ...IF SO THEN BAD PUMP RIGHT OUT OF BOX...BEEN THERE DONE THAT.
Aug 26, 2011 | 1997 Chevrolet Tahoe
I have a 1997 Chevy Tahoe 4 door V8 5.7 liter vortec. I replaced the fuel pump. I got good fuel pressure on the fuel rail up by the throttle body. It will start when I put fuel in the throttle body but it...
What is your fuel pressure with key on engine off? On these fuel systems if you do not have at least 52 psi or poppet valve inside the injector will not open allowing fuel thru.Let me know what it is i will try to help you.
Apr 16, 2011 | 1997 Chevrolet Tahoe
How to change the fuel pump on the 2002 chevy tahoe 2 wheel drive 4.8 v8
All vehicles for the last 25 years,have the fuel pump in the
fuel tank,drop tank,pump comes out the top
Dec 11, 2010 | 2002 Chevrolet Tahoe
Fuel pump repair
yes the tank has to come out then remove the lock ring at top of tank and fuel pump assy will come out
Mar 06, 2010 | 1997 Chevrolet Tahoe
Is there a access panel to change a fuel pump on a
That is not something many domestic auto manufacturers offer. that is mainly a foreign concept. you will need to drop the fuel tank which is a big undertaking for someone without the proper tools and equipment. I have heard of a local shop burning down in NYC because of complications during a fuel pump change.
Aug 26, 2009 | 1995-1997 Chevy Tahoe Ignition Starter...
Need advise on what to check, change, etc. on 99 chevy tahoe?
no,replacing the sending unit should fix the problem. haven't worked on one but typicaly you can just replace the unit on the fuel pump...(fuel pump and sending unit may be one piece)and have to replace both
Jun 02, 2009 | 2003 Hummer H2
I need to know how to change the fuel pump on a 1997 chevy tahoe
to remove the fuel pump you mus lower the fuel tank there ae two bolts on the back of the tank spray with wd 40 and use deep well socket 9/16 or 5/8 socket first lossen fuel hose clamp and over fill tube then unscrew the two bolts holding tank to vechicle, use a floor jack and a piece of plywood to lower the tank downone you have the tank on the ground tap the lock ring counter clockwise the tubes and wires come out of the center of the lock ring, tap it with a old wood chisel on two oppiste sides to get it to move once the ring is lose lift the fuel pump amd fuel sending unit out of the tank, replace fuel sock and o-ring on tank lube the o ring before installation and install in reverse proceedure replace main fuel filter, pull tank out and make sure there is no **** in the tank clen if there is. check the pickup tube for cracks. and put it back together and your set to go.
May 20, 2009 | 1997 Chevrolet Tahoe
1995-1997 Chevy Tahoe Ignition Starter Alarm Switch Logo
216 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
