Question about Brother HL 5140 Laser Printer
MY brother HL-5140 quits printing,and also has a black vertical line down the page before it quits. After a while, say 30 to 45 minutes, it will start printing again. But there are black smudges on the edge of the paper.
    New Friend:
  • 63 Answers
Sounds like a fusing error ... If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit) If toner is sticking to paper but the print quality is poor , replace the drum unit  (PCU)  good luck
Posted on May 03, 2009
Brother HL 5140 has black specks on the page
There's probably something wrong with the drum unit. I would check the manual on how to change the drum unit. Good luck!
Dec 30, 2011 | Brother HL 5140 Laser Printer
Need to get a total page count or report off of my Brother HL-5140
hold down the "blue GO" button on the printer intill it prints the report.
Have a nice day!
Aug 23, 2011 | Brother HL 5140 Laser Printer
How do you get a page count from an HL 5140/
On the HL-5140, you can print out a config page which will show the page count on it by pressing down the Go button (the blue button). Hold it for a few seconds, until the config page starts to print out.
To find configuration page instructions and page count tips for other printers, copiers, and fax machines, check out How to Print Configuration Pages.
Aug 22, 2011 | Brother HL 5140 Laser Printer
I have a hl 5140 printer and there are lines on the side of the page when it prints.
Hi
Hope I can solve your problem
The first thing is do you go to print preview before you print if you do and the line is there it might have something to do with your page border go to your page border and put on no border
It also might have something to do with not having your paper correctly in the printer make sure all your paper is the same in the printer and it is all straight
and correct at the time of print.
but my bet is that you have your page border on 1 side of your paperwhen you are doing a document up the top you have page borders make sure it is on no page border
I hope I helped
Jan 22, 2010 | Brother HL 5140 Laser Printer
Our Brother HL-5140 is not printing. It doesn't
Replace the paper pcik-up rolly assembly. MAKE SURE TO get a good look at how the existing one is installed before removing it. It needs a little tweeking to get the new one in and everything lined up correctly.
Also replace the separation page on the paper tray itself.
Look for part number PF-1 Kit or OEM PART #: LJ7920001
The only diagrams I could find on-line of the inside of the printer I found by searching for "brother pl-prn067". Look at pages 8-9.
Dec 09, 2009 | Brother HL 5140 Laser Printer
Black Vertical Line on the paper
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine;quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. if the issue is there at that point then it would point to the cartridge. if not then the fuser
Let me know....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Brother HL 5140 Laser Printer
Tonner flashing HL-5140- will not print at all, drivers are good
If you have the user manual look on page 3-1 for Control Panel. The different patterns of on/off/blinking lights indicate what the problem is. If the toner is flashing and status is green, your toner is low and should be replaced....
If you don't have the user manual it is at this link:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000071/HL5100_UG_ENG_3.pdf
see page 3-1 or page 81
Jan 18, 2009 | Brother HL 5140 Laser Printer
Black horizontal lines in printout
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
Nov 16, 2008 | Brother HL 1440 Laser Printer
Brother HL-5140 cleaning page?
There isn't a cleaning page on a Brother 5140. If the smudges are about 3.5 inches give or take a little and the same each time in a line it's probably the drum is damaged. If they are closer like 1-3/8" to 1-1/2" it will likely be the toner cartridge.
If it spaces out a more, something like 2-1/2 it will be the fuser.
Sounds more like toner cartridge though.
Hope that helps you.
Aug 14, 2008 | Brother HL 5140 Laser Printer
Won't print from usb or parrallel cable
check the usb sucket on the printer board and see if the legs are firm if ok check the board
Jul 19, 2008 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
379 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
