Question about Acer Aspire 3000 Notebook
Having problems with my sound video and game controllers
Mainly with the audio configuration
I have purchased my aspire 4730z last end of October still experiencing the sound is so weak when you played the video track. Do we need to buy some program to upload and make the sound bring our mood back?
Posted on Feb 21, 2009
Having audio problems
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
for windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps
Oct 29, 2012 | Dell Dimension 5100C (D51CL1) PC Desktop
Having problem with my soiud on motherboard p5sd2-vm on windows 7
The green 3.5mm audio input should be all you need. The speaker system should daisy chain. There is a speaker configurations in Windows. Go to Start > Control Panel > Hardware and Sound > Manage Audio Device > Sound. In Playback Check levels and configure speaker setup, like 2.1 or .1.
Oct 17, 2012 | ASUS Motherboard P5sd2-vm
When i am installed audio driver this the problem was occur and the installation stopped
Audio problems? no sound?
let us check your audio drivers first:
Determine Your Audio Driver VersionIf you have Windows 7*:
  1. Click Start > right-click Computer > Manage.
  2. Select Device Manager.
  3. Expand the Sound, video and game controllers section.
  4. Right-click your audio device and select Properties.
  5. Go to the Driver tab to view the current driver version.
If you have Windows Vista*:
  1. Click Start > Settings > Control Panel > System > Device Manager.
  2. Expand the Sound, video and game controllers section.
  3. Right-click your audio device and select Properties.
  4. Go to the Driver tab to view the current driver version.
If you have Windows* XP:
  1. Click Start > Control Panel > Performance and Maintenance > System.
  2. Go to the Hardware tab and click Device Manager.
If you have Windows* 98SE, ME or 2000:
  1. Click Start > Settings > Control Panel.
  2. Double-click System.
  3. Go to the Hardware tab and click Device Manager.
  4. Expand the Sound, video and game controllers section.
  5. Right-click your audio device and select Properties.
  6. Go to the Driver tab to view the current driver version.
let me know when you get more information.
Apr 27, 2011 | Intel DG31PR Motherboard
I have a problem with sound card alc888 does not configure with dg31pr
The Intel High Definition Audio with support for 5.1 surround sound and is designed for Windows Vista premium desktop and laptop systems only.
Determine Your Audio Driver Version If you have Windows 7*:
Nov 24, 2010 | Intel DG31PR Motherboard
Just installed new motherboard and now receive following message......itunes has detected a problem with your audio configuration. Audio/Video playback may not operate properly. How do I fix this?
Try reinstalling quicktime. Go on control panel uninstall quicktime. Then go to this url:http://www.apple.com/quicktime/download/win.html
Download it again. And install it again. Itunes should now work.
If it doesn't, for Video problems: Open QuickTime Player and go to 'Edit' -> 'Preferences' -> 'QuickTime Preferences' -> 'File Types' -- check here to see if the file format of your problem video files is selected.
For Audio problems: Open QuickTime Player and go to 'Edit' -> 'Preferences' -> 'QuickTime Preferences' -> 'Audio' -- Here you will see a Device is needed that will play your sound. Select 'Audio Playback and Recording Devices', If you are having an Audio problem it may be due to having no device or an improper device.
Good Luck
Nov 25, 2009 | Dell Dimension 9200 PC Desktop
No audio
stupid answer but did u check the audio settings in the main menu from the ps3? i reset my ps3 on accident n the audio changed to component but picture stayed on HDMI
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
No sound in my laptop
Hi
Go to device manager (start-in start search type device manager)
Select Sound & Video game controller - uninstall the audio device on high difination and install the UAA and Audio driver (after installation of UAA do not restart the sytem) - Configure the drive manually from the device manager by locating the driver manually
Mar 17, 2009 | Dell Computers & Internet
Audio
Go to the Device Manager (right click My Computer > Properties > Hardware), and locate "Sound, video and game controllers". Right click the audio device and click Uninstall IMPORTANT: Make sure you have a copy of the setup for the drivers. http://support.dell.com/support/downloads/devices.aspx?c=us&cs=19&l=en&s=dhs&SystemID=INS_PNT_6000&os=WW1&osl=EN
May 25, 2008 | Dell Inspiron 6000 Notebook
Problem: I am trying to Hook up my RX-Z9 and get sound out of MAIN.
Try pressing "Main A" or "Speakers A"-button on the remote-control (slide the shield at the bottom)
Nov 14, 2007 | Yamaha RX-Z9 Receiver
Help me
Same problem - Solved! Thanks Guys! I have Vista so the procedure was a little different. I went to Control Panel - Hardware and Sound - Manage audio devices. Once there I disabled the multimedia device and defaulted to the speakers which makes me fully operational again. Now I can crank Tequila! by the Champs.
Nov 09, 2007 | Audio Players & Recorders
Acer Aspire 3000 Notebook Logo
85 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
