Question about RCA D52W19 52" Rear Projection Television
Rca d52w19 push power flashes 3 times and makes a buzzing noise each time, but does not come on. I Checked capacitors cp150,cp114,cp120 and none of them show any signs of bulging or leaking. I also replaced my flyback and cp150, but im still having the same issue. What else should I try?
  • 4,234 Answers
The caps in these sets rarely bulge. Try checking the Horizontal Output Transistor (HOT). I suspect that it is shorted. The noise you are hearing is the power supply attempting to fire. With the defect further on, the power supply will turn itself off as a safety valve.
Keep us posted,
Dan
Posted on Feb 21, 2009
I have a RCA d52w15byx1 when you turn it on, the power light flashes 3 times then goes out...what could be the problem?
Thats usually caused by failed power capacitors CP150, CP120 and CP114 you can get the RCA CP150 CP120 and CP114 re[pair kit from www.tvrepairworld.com which comes with instructions. That will usually solve the 3 flash issue.
Dec 10, 2011 | RCA P52926 52" Rear Projection Television
Power button is pushed blinks 3 times then nothing
sounds like the cP150, CP120 and CP114 capacitors need replacement. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Mar 02, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ge d52gw12 green power light flashes three times wont power on
sounds like the cP150, CP120 and CP114 capacitors need replacement. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.Its listed under the RCA repair kits as RCA makes the GE models.
Feb 24, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
When turned on the green light flashes 3 times. No picture.
replace CP150, CP120 and CP114 capacitors. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit contains the caps and the CD with instructions.
Feb 15, 2011 | RCA D52W19 52" Rear Projection Television
When I push the power button the light comes on then flashes 9 times and turns off, tv never comes on.
CK the deflection board for bad capacitors CP150 2200uf 16v use 25v CP114 CP120 220uf 35v If any of them is vented,puffed up on top then replace all 3 Capacitors.
Deflection Board is bottom left hand side with FBT flyback Transfomer.
Sep 28, 2010 | RCA D52W19 52" Rear Projection Television
Tv turns of and on 3 times but does'nt start up
The number 1 cause of that is failed capacitors CP150, CP120 and CP114. You can get that repair kit from www.tvrepairworld.com which also contains instructions.
Mar 03, 2010 | RCA D52W19 52" Rear Projection Television
I turn my 50" rca on and the power light goes on and blinks with no sound and no picture the powers down ... help please
Look for a pattern in the Blinks then check for an error code in your user manual. It will tell you what has failed.
Dec 29, 2009 | RCA D52W19 52" Rear Projection Television
I have a RCA d52w19. when I turn it on, the LED flashes 3 times and shuts off. Basically the same problem as everyone else. However, I changed CP150, CP120 and CP114 and still have the same problem. What...
if you replace the bad cap,s cp114 cp150,cp120 and still give you flashes 3 time you do have a bad flyback 21.40 for the flyback but in the same fix you see 3 fuse by the flyback hit them with solder thay is the power supply for the conv, borad.i work for quaker tv i seen a lot of that d52w19. you mite whant to look at the power wire that go to the front buttom con,t in front of tv if thay are pich in eny way the set will not come on. but you have a bad flyback.
Dec 07, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w19 push power flashes 3 times and makes buzz each time
Check capacitors cp150,cp114,cp120 if any of the capacitors are puffed up on top replace all 3 of them 2200uf 16v and (2) 220uf 35v
Feb 14, 2009 | RCA D52W19 52" Rear Projection Television
Rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
210 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
