Question about HP (367799-001) Motherboard
HP Pavillion dv1000 laptop will not power on
Measured output voltage of power brick to be 18.5v as it should be so laptop is receiving power. No LEDs light up on front, and unit will not power on.
Does this automatically indicate motherboard failure? Is the most likely resolution to replace the entire motherboard assembly?
  • 538 Answers
Cold solder on DC connector. Most common problem.
Posted on Mar 20, 2009
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
How cain i connect my laptop Hp pavillion dv 1000 to TV
you can purchase a usb device with TV outputs. look on ebay or purchase one from your local PC retail shop.
Apr 16, 2010 | HP Pavilion dv1000 Notebook
My hp pavillion dv5t-1000 power cord not working
Test your voltage on your power supply...There should be a voltage amount on the sticker on your power supply telling the output.Make sure yours is putting out the right amount.If this test good,your probally looking at a bad dc jack.Jacks need to be checked by a certified repair person.....Goodluck......If this is helpful ...Be so kind as to give a testimonial.....Thank you
Apr 09, 2010 | HP Pavillion DV6227 Notebook
I bought a new ac charger for my hp pavillion dv1000 it will not power on
Check and make sure the Voltage on the AC adapter is the exact same as your previous one. Just because the connector fits in the port, doesn't mean it's the right one. Look in your manual to figure out if your AC adapter voltage is correct. If it is, it's possible that you have a dead battery, it happens when surges happen during power outages. If it's so, look on the HP website for a new replacement battery. It should allow you to type in your pavillion model number.
Jan 08, 2010 | HP Pavilion dv1000 Notebook
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
Hp laptop issue
can u explain....only icons are not showing.??? what abt the start menu and all other applications.? does it work fine..?
Dec 22, 2007 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
241 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
