Question about Gateway FPD2275W LCD Monitor
White screen turn n computer and monitor stays white
  • gzap2002 Feb 21, 2009
    thank will try these suggestions
  • stemar2002 Feb 21, 2009
    my lcd scren is white when turned on, i tried another screen and its working! what colud the problem be?
    Problem Solver:
  • 5 Answers
The first step would be to plug in a known working monitor and see if a similar problem occurs. If it does, then the problem is with the video card, a software driver or the computer itself.
Posted on Feb 20, 2009
  • caller4dance
    caller4dance Feb 21, 2009
    If the problem is the monitor, the first thing that I would check is
    the cable. Are any pins bent on the connectors on either, side. If
    so, tortake a pair of really small neadle-nose plyers and straighten
    out what is bent or replace the cable.
    If a problem exists with another monitor, turn off the computer, unplug the power cable and the monitor cable, remove the case cover and find out if the video card is attached or part of the computer's motherboard. Is it a separate card that is plugged into the motherboard? If so, get yourself a grounding wrist strap put it on your non-dominant wrist and attach the clip to the metal on the case, next, try removing the card and re-seating it in the slot. Reconnect the power cable, reconnect the monitor cable and start the computer. If that didn't solve the problem we'll try something else.
My monitor screen stays on at start up for a few seconds, then turn completley white. Ive tried restarting, shutting down, changing monitors. Whats wrong?
If it happens with multiple monitors, maybe it's not the monitor that's the problem: your graphics card might be dead, and that's why it turns white.
Oct 16, 2013 | Epson Viewsonic ViewPanel VE150M Monitor
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
Turned on monitor and screen stays white no icons..etc
It sounds like the T-CON board (part of the LCD panel assembly) is not getting 5vdc. Check the power supply and logic bd caps. Check fuse on the T-CON BOARD.
See LCD panel pictures and bad caps:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manuals: http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=al1716&kategoria=monitor&kat2=schematics
May 15, 2010 | Acer AL1716B 17" LCD Monitor
Monitor goes white.
if the monitor turn white but the power light is stay on with green, then probably the back light tube was defective, and it will happen randomly in beginning and getting worse after while.
Jan 14, 2010 | BenQ FP71E 17" LCD Monitor
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Moniter stay white when turn of computer
If you turn off the computer you should be turning off the monitor as well.. is the monitor still white when your monitor is set off? if not, then its normal.
Aug 16, 2008 | Computers & Internet
17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Jun 19, 2008 | Star Logic 17" LCD Monitor
White monitor
You can degouse it.I think you placed your monitor in any magnetic field or near fan ac or any electric equepment.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | Xerox XA7-172i 17" LCD Monitor
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor goes to white at cpu shutdown
The problem is in the "soft switch" technology: On some of Sylvania's newer monitors they have incorporated what is called "soft switch" technology. This allows your ATX power supplied computer to turn your monitor on and off using it?s software controls. Therefore, your monitor?s light will always stay on blinking even when your computer is off. The monitor in normal operation consumes about 80W of power; in the "OFF" state it will be reduced below 8W. The "OFF" mode of the monitor can be controlled by the PC input signal or by pushing the soft-power button to disable the PC signal control for manually turning off the monitor screen. Thus, when the monitor is in soft-power "OFF" mode it still consumes a very small amount of power. For the purpose of making it noticeable to the user that the monitor is in soft-power "OFF" mode, we designed the power indicator to provide for a slow blinking signal (every 2 seconds). If you need to totally turn off the power, then the power cord would have to be unplugged. The same is true of the PC itself, but the PC does not provide for notification while in "OFF" mode. Your monitor looks like it may be in need of repair, contact info: PTI Technologies Inc. 7372 Doig Dr. Garden Grove, Ca 92841 Phone: 714-799-3899 Fax: 714-379-6290 Hours: Mon - Fri 8:00am to 6:00pm PST
Nov 19, 2005 | Sylvania L181 18.1" Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
98 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
