Question about Crate SPA1600 Power Amplifier - SPA Series Car Audio Amplifier
Intermittent shorts in a Crate Limo TX50DE Guitar
Intermittent shorts in a 7 year old Crate Limo TX50DE Guitar amplifier.
Symptoms: Both the Voice Channel and the guitar channel pop, rattle and cut-out for no apparent reason.  Also the guitar channel only works on the ''clean'' setting.  The distortion side of the amp is non-functional completely.
Finally, the ''effects'' seem to switch around on their own.  I set it at a light reverb, and pretty soon it's got ''chorus'' or something else instead.
I've already spotted some poorly soldered pot connections, but I suspect more issues.
I'm looking for a schematic.  I have an engineer friend with an affinity for electronics (and specifically guitar amps) who has offered to debug it for me-provided I can locate a diagram).
Thanks.
  • ampman72 Apr 27, 2009
    Need schematic for crate limo TX50DE. Getting 5 volts DC on speaker outputs.
    Scholar:
  • 73 Answers
Turn that ****** on and get a can of freeze spray. coming and going type issues is usually related to a failing electrolytic capacitor. there may also be a bad mosfet, rectifier, diode, etc. i would be suspect to caps. schematics probably only available thru crate and you have to pay a couple bucks, but trust me its worth the couple bucks spent and having it on its way than wasting hours online not getting anywhere. by the way i checked my sources and came up with nada.
yostamplifier.com
Posted on Jan 21, 2010
Hie, I Have got a crate tx 15 and, I have a sound problem, all time I have got a buzzzz... but there another thing too, the led for the battery recharge does'nt light and when I plug the electric...
Your symptoms would indicate the battery is defective. When a battery fails, its internal resistance goes up and they PROBABLY use this battery in place of having a separate filter capacitor so you will get hum or buzz as a result and no charging indication.
Sep 13, 2011 | Crate TX15 15W Guitar Amplifier
Crate Guitar Amp G120 cxl not outputting sound ... What troubleshooting steps should i take before purchasing new module?
I had a Crate G120C XL COmbo amp that was only outputting very quietly. I checked all pots. They were operating as they should be. I checked the speakers outs, the footswitch and its connections and both guitar inputs ..all operational. Problem: turns out when you plug an effect into the effects loop, there is an internal switch that lets the rest of the circuitry know an effect is there and routs the correct internal signal to it. As soon as I plugged in a pedal, Voila!!!! Full volume was completely resorted, no problem at all. So at this point I can either limp along with a pedal in the loop that isn't even doing anything, or I can go inside and repair the switch OR bypass it (short it out) so the loop is no longer functional.
There are other situations that can cause the same symptoms, but this is what was happening in this particular case. Amp cost me $50, sold it for $225. Nice. Got me another one-- almost same low price.
Oct 16, 2010 | Crate SPA1600 Power Amplifier - SPA Series...
I have a Fender Telecaster guitar and a Crate amp that cuts out i
The next time it stops, unplug the cable from the guitar and touch the tip of the connector with your finger. If the amp hums, then the amp is still working and the problem is in the guitar. If there is no hum from doing this, then the amp has am intermittent.
Try this before it fails to see what to expect in the way of the hum from this test.
Common problems with the amp are OFTEN with a broken input connector or bad switch on the preamp output jack if it has one.
There are MANY other things and without troubleshooting it is hard to steer you to a fix.
Mar 26, 2010 | Fender '72 Tele Deluxe Electric Guitar
Dirty high switch on a Crate practice amp
NEVER use switch cleaner such as DeOxit on pots !!!!!
I have used CRC226 available at Home Depot electrical dept.
I SUSPECT that the resistance element in that pot is cracked. This is common if the knob sustained a hit. Replacing the pot is the only cure if the element is cracked.
Reviewing the schematic, ALL audio passes through the wiper on the HIGH tone pots. If the wiper is intermittent, so will be the sound.
If your unit is solid state amp, the pot looks like a 10K ohm LINEAR taper.
If you have a tube type, then the pot is a 250K ohm LINEAR.
Note that the other tone pots in the units are AUDIO tapers, but the high is a linear taper.
Get repair parts from either DigiKey.com or Mouser.com
Mar 23, 2010 | Crate Music
Crate gtx 65 guitar amp mains hum
I had the same problem on my VTX65. I noticed it would oscillate with different effects so I removed the effects module. Problem solved. Now it's dead quiet. I use a Digitech RP500 so removing the effects module was a non issue.
May 19, 2009 | Lexicon LX-7 7-Channel Amplifier
Setting knobs for amplifier
Hi gv6257
What sort of amp you play. I will help you sort it
regards
tobotek
Dec 27, 2007 | Audio Players & Recorders
Guitar/amplifier 'buzz'
I have two amps .i need to know how to set the knobs on them. to get the best sound out of them .i have a crate and a drive elite.i am a beginner. they are both bass amps. so PLEASE HELP ME
Dec 27, 2007 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Crate BT50 Bass amp cutting out with high input.
Sometimes an amplifier's preamp can't handle certain signals/frequencies at a high gain, so they cut out. Bass guitars are especially prone to giving such a strong signal.
I bought an older, nonworking bass amp recently and fixed it just to find it had the same problem. Best solution is to put a low ohm resistor at the amps input, but if you turn your guitar down to half volume it'll have the same effect: should prevent it from cutting out.
Nov 01, 2007 | Crate SPA1600 Power Amplifier - SPA Series...
Open Questions:
Crate SPA1600 Power Amplifier - SPA Series Car Audio Amplifier Logo
468 people viewed this question
Top Crate Car Audio & Video Experts
xxxxxx xxx
Are you a Crate Car Audio and Video Expert? Answer questions, earn points and help others
