Question about HP Photosmart 3210 All-In-One InkJet Printer
Hp 3210 photosmart Is it possible to print from black cartridge only,
    Novelist:
  • 180 Answers
It is possible. You will have to go into the properties of the printer you're using. Assuming you're using WinXP, go to Start>Printers and Faxes and right click your color printer. Choose Printing Preferences. Using my HP Photosmart C3100 as an example, I would next choose the Color tab and under Color Options, choose the radio button that says Print In Grayscale. That will do it.
Posted on Feb 21, 2009
5 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: Error Message OXc05d2381 on HP Photosmart 3210
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
mgdev24
  • 59 Answers
SOURCE: hp 3210 photosmart all-in-one printer
check the catridge number size if is the same with the one that come with your printer if is not the same number then the one you buy is not conpactable with your printer so it can work unless you get the actual number of the one that come with the printer. but if the size is correct then check the fixing again and fixe it properly. or you check the printer software uninstall it then reinstall it back, also, your can check the container the ink store in when the printer finish printing inside the printer in some cases if their is alot of ink setle in that container the printer will not ready so what you do is that there is a fome in it that **** the ink bring it out and clean it very well then put it back.
Posted on Nov 17, 2008
  • 8 Answers
SOURCE: HP Photosmart 3210.
Look at "black ink problem" higher in these posts. 9 people offering solutions.
You may need to force the blockage out of the black ink feeder system.
This is a serious design fault which HP will not acknowledge.
Posted on Jan 07, 2009
pineworks
  • 4041 Answers
SOURCE: hp photosmart 3210 error oxc18a0206
Hi there
This is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 13, 2010
Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
Dec 24, 2012 | HP Photosmart 3210 Printer
My HP photosmart 3210 skips lines on the black ink only. The other colors print fine.
(The obvious) Replace the black cartridge. Even if ot says you have ink you could have a faulty cartridge, even if it has worked fine in the past. (The not so obvious) Clean your printheads/nozzles. Repeat the process a few times.
Apr 27, 2011 | HP Photosmart 3210 Printer
I have a hp photosmart 3210 all-in-one and it keeps printing the same thing over and over as soon as you turn it on
It can happen due to different causes:
If the cartridges are new, the automatic alignment process is not complete, for that:
1.Turn off the printer and turn it on again
2.Let the printer print the allignment page
3.After printing the alignment page, disconnect the USB cable which is connected behind the printer
4.Place the allignment sheet inside the scanner glass and press the scan button on the printer
The alignment is complete when the printed page is scanned
Turn off the printer and turn it on again, it should be fixed
The other possible causes might be:
The cartridges are not correctly installed or one of the cartridges is defective.
In that case reinstall the cartridges after cleaning them with lint free soft cloth.
If that does not work, then at least one of the cartridges need to be replaced
Apr 24, 2011 | HP Photosmart 3210 Printer
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
My HP Photosmart 3210 printer is not printing black color
must be dryed ink on ink cartdrige, or dirty print-head (ink cartdrige) conntector.
try these :
To clean the print head from the control panel
1. Load letter or A4 unused plain white paper into the main tray.
2. Press Setup.
3. Press 5, then press 2.
This displays the Tools menu and then selects Clean Printhead.
or
To clean the ink cartridge contacts
1. Unplug the power cord from the back of the HP All-in-One.
2. Lift the ink cartridge access door.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch.
4. Inspect the ink cartridge contacts for ink and debris buildup.
5. Dip a clean foam rubber swab or lint-free cloth into distilled water, and squeeze any excess water from it.
6. Clean only the copper-colored contacts.
7. Place the ink cartridge back into the empty slot and press down on the gray latch until it clicks into place.
8. Repeat if necessary for the other ink cartridges.
9. Gently close the ink cartridge access door and plug the power cord into the back of the HP All-in-One.
These steps is printer manual on pag 99 and 100
Jan 15, 2010 | HP Photosmart 3210 Printer
Have a photosmart 3210 all in one and i just want to print in black and it wont because a color cartridge is empty is there any way to bypass this
Remove the color cartridge, it will run on "Ink economy mode" or something like that. It WILL print from windows but the copier wouldn't work, displaying error. The copier needs both cartridges installed to work.
Nov 04, 2009 | HP Photosmart 3210 Printer
The black cartridge does not print. It is full.
Generic comments
Does your cartridge require "installing"?
Id suggest you remove it and reinsert it, making sure you seat it properly. You did remove the tape that seals the cartridge, right?
Then open your printer in the control panel ... print a test page. (check for options you may have on themaintenance tab, if available)
I hope you find this useful
a.
Sep 23, 2009 | HP Photosmart 3210 Printer
Colour cartridge missing but I only want to print
No you cannot. Each one of your cartridges is smart chipped. When this cartridge registers as empty it acts as an on/off switch thus turning the printer off.'
You need to replace the empty cartridge in order to print.
Go printer settings and check option to print only black.
Jul 30, 2009 | HP Photosmart 3210 Printer
Black Ink shows empty even after installing on HP Photosmart 3210
These cartridges are really only ik resovoirs for the printer. It does have an ink flow sensor, though. If the printer does not recognize the ink level, it is possible that you got a cart with a bad chip. I refill these alot, and all you can really do is check the chip on the cart and make sure nothing is on the contacts...otherwise replace. A good step would be to put the old cart in and see what happens...
Mar 10, 2009 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart 3210 All-In-One InkJet Printer Logo
267 people viewed this question
Ben Johnson
