Question about Singer 1525 Mechanical Sewing Machine
Don't know how to use
I just got a singer 1525 and i have no idea how to use it. There are two knobs at eye level, and then different stitches.. how do i do jsut a basic straight stitch. what number should the right and left knob be on and what stitch?
  • 26 Answers
First if you have a manual then fine you can read it but if you don't try threading it and try it out. see what it does at the setting it is at. then change one thing at a time and note the positon everything is at now. probably easier than you think and remember you can't break metal?? can you?? don't be afaid to try it. not being mean or anything but until you see what it does you really can't figure anything out. YOu maight try cleaning out the old lint with canned air and change the needle if you find it burred on end or even bent slightly. good luck
Posted on Mar 08, 2009
Need to know what the knobs are for
Are you sure that it's a Singer LS-1217? I can't find any model with 1217 on the Singer site.
The Brother LS-1217 manual is available here: . The direct link to the English version of the manual is . There are only a few knobs on most machines. On the front near the needle is the Needle Thread Tension knob. If you use contrasting colors (different top, bobbin and fabric colors), you might see a straight stitch where the top thread is visible on the bottom of the fabric for example. Adjust the tension to get both the top and bobbin threads meeting in the middle of the fabric layers. (Increase the needle thread tension - rotate to a higher number but go in 0.5 increments.)
Then you have near the motor area the stitch width and length knobs. The width is only for zigzag stitches. A long stitch length is good for a temporary seam (like basting in a zipper or hem) before you finish that area. However, the width and length should be adjusted depending on the fabric. A fine fabric needs a smaller stitch, usually. The knob on the right side of the machine is the balance wheel (or hand wheel). This adjusts the needle height so that you can have the needle out of the way while changing the bobbin, for example.
I hope this helps.
(I use the Singer Sewing Book as a reference for tension issues.)
Feb 20, 2013 | Brother LS-1217 Mechanical Sewing Machine
Drop in bobbin on singer 6234 will not thread empty Bobbiin thread winds around underside od bobbin
try using a different bobbin and see if that helps, if it doesn't
then the machine may need to be checked to see if there is
something wrong with the hook and the hook race.
Nov 29, 2012 | Janome Jem Silver 662 Mechanical Sewing...
Missing stitch selector knob on singer 2932
call sears parts direct & ask them about the part
Jul 10, 2012 | Singer Sewing Machines
Stitches don't lock singer 185j
try a new needle & see if that helps the stitches
also clean under the needle plate for lint
try singer customer service about a manual
these you will have to email about the manual
May 12, 2012 | Singer Sewing Machines
A friend gave me a Singer 1120 with no manual. How do I change stitches on this machine?
The stitch window shows the letter that corresponds with the stitch you want so if you turn the dial on the right side of the machine to E you get the stitch under the letter E, turn it to B and you get the B stitch. If you want something in the RED row below, just turn the knob on the top front on the machine to the RED MARK and then you'll get the stitches on the red row. I think the mark is on the stitch length knob on the right but I'm not sure since I don't have this machine but i have taught someone that has it. Just look for it on that know first. If you need to order a manual contact Ron at and ask him for one. Hope this helps.
Aug 23, 2010 | Singer 1120 Mechanical Sewing Machine
How do I reverse stitch on a singer 362 fashion mate model
The large knob in the center of the stitch length dial is a button, push it in to reverse stitch. Hold in as long as you need to reverse stitch, then release to resume regular stitching.
Jan 09, 2010 | Singer Sewing Machines
Dropped stitches troubleshooting:
1>change to a new proper needle (proper needle means quilting needles for free motion, stretch needle for knits, leather needle for leather, microtex needle for micro fabrics.....etc.) of proper size. Most sewers never need a needle smaller then an 80/12 when sewing. Smaller needles bend more easily causing more problems.
2>If a new needle doesn’t fix the problem, remove parts from bobbin case area (as best as easily allowable) and clean out all the lint thoroughly, and oil with 2-3 drops of oil where friction occurs (turn hand wheel and look for rubbing)
3>If still skipping, try a different spool of thread (Yes, thread can caused skipped stitches, not common but I see it).
4>If you haven’t solved it yet, sounds like you could need to make a lower level adjustment like hook timing.
Hook Timing:
To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher
Mar 20, 2009 | Sewing Machines
Singer Esteem I lost manual and need to know how to get it on the stretch setting. Thanks!
Also, you can go to and download a manual for free, and then print it after you save it.
Jun 23, 2008 | Singer 3116 Simple
Singer 1525 Mechanical Sewing Machine Logo
144 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
