Question about Whirlpool Duet GHW9150P Front Load Washer
My washer displays a flashing number F 06 and will not spin? have a tech coming monday but no help today.
  • Anonymous Feb 21, 2009
    I have the same problem...we are tearing into our washer as we speak! It's the bearing. The F0 6 means the spin isn't working. Looks like we have to replace the entire tub! Good luck with yours. We are going to have to call repair guy also...
    President:
  • Whirlpool Master
  • 2,651 Answers
Not ness a bearing issue, f06 is a communication issue between the motor and the motor controlller, check the connector from thne motr to the board mounted the lower left front corner, ive even seen excessive moisture in basement( high hunmidity) or perhaops a leak from a hose up above .. last F06 i encountered a nail was lodged between ithe inner and outer tubes preventing it form free spinning.. a bad rear bearing is unmistakable, sounds as if a helicopter is landing in the laundry room
Posted on Feb 21, 2009
When the washer mark nd,what that mean?
SAMSUNG Silvercare Front Load Washer will not drain ...
? 3:06
www.youtube.com/watch?v=JozFGnPsQvA
May 4, 2013 - Uploaded by eallevato Troubleshooting a Samsung front load washer that is displaying ...Ordered a new pump and still no spin and "nd" code comes on after a while.
Sep 27, 2015 | Washing Machines
Whirlpoool front end loader washing machine showing an f 06 error
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
Nov 04, 2012 | Whirlpool Washing Machines
Front load washer doesn't spin or wash -
Here is what you do:
Disconnected every cable to the MCU and CCU (one at a time) and reconnected them making sure each connection is good the run the machine. If the error code
is comes back, replaced the motor that has the tachometer.
Go www.appliancerepairclinic.com and order a new motor.
Oct 12, 2009 | Kenmore 44102 Front Load Washer
Washer stopping and flashing F 06 fault
F/06 ---- ERROR IS FOR ----------- Drive Motor Tachometer ErrorThe control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.----------
AND TO SOLVE THIS ---------Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) --
Check the MCU
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes washer won't drain - digital display shows LD
looking at the tech sheet for this, it appears to be a standard whirlpool top load but with electronic controls, correct? normalling with this type a lid switch is the issue but the electronics would have a different code for this, LD is Long Drain for this model. suspect a transmission but this should help you troubleshoot. go to www.servicematters.com and click technical reference - tech library - tech sheets, enter model minus 110.prefix. this will show tech sheet with diagnostics. this book can also be found inside your console.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Model 110.45962.400 code comes up f 06
The following link explains the "F06" error code on a Kenmore Elite:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
In a nutshell, the error is an indication of a Motor Speed problem. This means there is a communications problem between the Central Control Unit (CCU) and the Drive Motor or Motor Control Unit (MCU).
However, before assuming there is a problem, unplug the washer for at least 30 minutes. In some cases the washer can experience momentary computer glitches. The 30 minute interval is necessary to reset the computer. Sometimes this is all that is required to clear some error codes.
If the error code returns following a reset, follow the advice given in the link to determine the fault.
I hope you find this information helpful. If you require additional assistance, please let me know.
Sep 27, 2008 | Kenmore Elite 45986 Front Load Washer
Will not spin o6 F code
06 fault codes indicates a tachometer motor fail. meaning the tachometer was not able to record the speed of the motor . check for wiring harnes at the tachometer, check for dirt on the tachometer itself. check also wiring from the motor control board to main control board.
Feb 21, 2008 | Whirlpool GHW9100L Front Load Washer
Frigidaire Affinity ATF6000ES Error code E-48
you might have some thing in the pump check pump first if Therese nout in there then it might be your brashers you will have to look on ebay and don't for get to wright your model number down there really cheap if you get stuck get back to me i will help
Dec 15, 2007 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
83 people viewed this question
Dan Webster
Dan Webster
Sal De
