NuTech NU Dolphin (4 GB) MP3 Player Logo
A
Anonymous Posted on Mar 03, 2013
Can i buy a screw in usb cable
Is it possible to buy the 2/5mm usb cable mine is broken
1helpful
My drive fall form table i was tryed it is not working and not able to read my data that drive needle getting tick tick sound coming what can do?
The continuous "tick tick" normally means low power on the device.
Means: Case board broken or hdd logic board fault.
Possible solutions:
- Try to change usb port and usb cable.
- If you have an usb power adapter try to connect it JUST for some seconds to see if the disk spins.
Warning: you can burn your disk because the classic usb omputer port use a 500mA max power while an USB A/C normally can offer up to 2000mA.
- Buy a cheap 2.5" hdd case and put on it your 160gb hdd because the board of the Apollo could be broken. In this case check before buying if you need a SATA or a PATA interface.
If nothing changes, sorry, your hdd is probably dead.
My psp go has run out of batterie and no longer charges pls help
There are two possible causes for this, one your charger is broken, in which case you will need to buy a new one. Hopefully thats the problem, because the only other possibility is that the Charging port is broken, in which case you will have to send it to Sony to repair. However, there is a work around to the second problem. My psp has the ability to charge via its USB port, if you have a compatible USB cable, connect your psp to your computer and see if that will work.
I accidently didnt screw in the ear phones tight enough, and now i think water has got in. please help. nicky bradley
If it's broken and you want to buy a new one I'll buy the old data cable from you- I lost mine! There's a new touchscreen one out- so you could update and I could get a cable. My email address is miss amber jo stanley at hotmail dot com (no spaces- I've typed it like this to avoid junk mail).
4helpful
2answers
Can i charge the camera other than through the usb cable ??
Hi!
USB charging is not possible. You need to have the battery charger to be able to fully charge the battery. This should come along with the camera kit.
USB charging is possible if you will buy this: http://fujifilm.co.uk/consumer/digital/digital-accessories/usb-chargers-travel-adaptors-153171/world-adaptor-plus-usb-charger
"For charging by USB, simply change the head and plug in your iPod, mobile phone, PDA or any other 5V USB powered device to keep it fully charged wherever you are."
2helpful
3answers
My PC cant find my PSP even im connecting with a usb device....
Sorry about this, your usb port on your psp could be possibly damaged. So you can use a memory stick on your memory card reader to do your data transfer. If you insist on using the usb connection then try seeing a sony repair personnel for this.
Regards
4helpful
Flat cable
http://www.specialty-cables.com/flat-flexible-cables.html
E-mail them. They have Flat Flex Ribbon Cables, from 0,5mm to 2,5mm pitch, and 3 to 40 conductors - so they have the cable you are looking for. Please rate me :)
1helpful
Usb cable
Players use standard USB, Mini USB, or Micro USB. I believe the one in title uses Mini USB cable.
To get a replacement cable go to any computer shop or camera shop and buy a Mini USB cable, take the player with you and show it to the shop assistant to ensure you are buying the right cable.
Regards.
4answers
Sony Walkman NWZ-S615F Black Digital Media Player
You can by the cable in Wallmart, Staples, Bestbuy, Cercuit City etc. These will do enough !
Top NuTech Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a NuTech Audio Player and Recorder Expert? Answer questions, earn points and help others
