Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
Husky 17gal 5hp compressor will not cut off when it builds up pressure. Pressure valve will pop open and then I cut it off buy hand
  • Anonymous Feb 22, 2009
    pressure valve pops open and compressor keeps running. it is a kobalt 80 gallon
    Champion:
  • 205 Answers
Bad pressure switch or it is wired incorrectly replace switch and check the wiring or could be out of adjustment you compressor is made for max 125psi should be a screw to adjust on the pressure switch near where the wires are connected back out counter clockwise to lower and see if that turns it off
Posted on Feb 26, 2009
Turning the switch to on, there is no power getting to the compressor.
What do you think could be the problem?
Posted on Nov 08, 2009
POP OFF VAVLE ON HEAD KEEPS POPPING UP
The over-pressure relief valve may be defective if the valve is opening before the desired tank pressure is reached. If not, then the shut-off pressure adjustment (if there is one) may be set wrong. You'll need to find out from the manufacturer exactly what static tank pressure the compressor is designed to provide and then determine if it is working correctly. If so, then the relief valve might be defective. DO NOT attempt to defeat the relief valve under any circumstances - it can result in compressor damage or a dangerous tank failure.
Oct 06, 2014 | Porter Cable 175 PSI 80 Gal. Oil-Lube...
Can I adjust the tank pressure on a Husky 1506 compressor. pop off keeps engageing, so I need to adjust so that compressor shut off automatically
Before you change any parts, check that the pop valve is not faulty. Look closely at the pop valve to read set release pressure. If the valve is releasing before marked reading, replace valve instead to one slightly higher. The pressure may or may not be adjustable at the switch (need to replace the switch) depending on switch installed at the factory (parts list does not give enough information). If your switch has a remove-abel cap with adjustment screws/nuts, post again with model number of switch for info on adjustment. Good luck
Oct 06, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a husky brand air compressor with 7.5 h.p. compressors. when pressure builds to its maximum amount, compressor will not shut off it continues to run while pop off valve opens.
Ypur pressure switch ( the grey box), is not shutting the motor off. It is is either adjusted higher( too much pressure), or stuck. Unplug it and remove the cover, Then make sure the gold colored lever moves. This is what shuts the power to the motor off. You can plug it in and watch to see if the lever moves before the pop off blows. It depands on the tank rating as to what pressure yours should be set to. Around 125 psi is recomended.
Hope this helps.
Dec 31, 2010 | Air Tools & Compressors
Husky 202900 when i turn it on motor runs but it but will not bui
when i turn it on motor runs but it will not build up air pressure
Apr 13, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky Q26 will not build pressure. Where do I buy parts?
First check the check valve and also if it has an unloader valve make sure it is closing.
The main check valve is often right where the air goes into the tank. The unloader can be integral to the pressure switch or on the compressor.
Sep 26, 2009 | Air Tools & Compressors
I have a Husky model Y6010 air compressor.
First remove the valve using probably about a 1/2" wrench but make sure there is no pressure in the tank before you do so. check the cone and seal by loosening the valve by hand and check for debris. If there is no debris then the problem is either the pressure relief valve or weak pressure regulator but may also be a bad piston seal if it is a direct drive unit.
Apr 28, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
The compressor relief valve keeps popping, compressor runs
What pressure is it popping off at? You might have to adjust the pressure switch to a lower setting.
Apr 01, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
The pump builds up pressuer to 80 to100 psithe motor cant turn any more due the pressuer in the pump, can you tell me why this happens dayton compressor model 5Z592 5hp it had a 3phase motor when it was...
hi your problem sounds like the non return valve is either missing or is passing back pressure
the nrv should be on the hose that supplies the tank
Mar 24, 2009 | Air Tools & Compressors
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
1,268 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
