Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1995 chevy 1500 pickup 4x4 4L60E trans
What years will fit my pickup to replace it? can i change it to a 4L80E?
  • 79 Answers
The computer is different on the 4l80e put the wiring should be the same. the case has the same bolt pattern. The bolt pattern stayed the from on the pickups from atleast 2001 down. You can use an LS series style motor's transmission if you wanted. You will just have one less bolt in the transmission case to the block.
Posted on Jan 10, 2010
1995 GMC 1500 6.5 turbo with a 4l80e trans got lazy going into forward and reverse< changed the filter and fluid. worked better for a couple days then lost everything. what can I do to fix this problem?
you are going to have to replace the internal clutch discs in this trans or buy a rebuild if you have not worked on transmissions before then bite the bullet and buy the rebuilt one
Mar 07, 2015 | GMC Cars & Trucks
Can a 94 chevy cheyenne transmission interchange with a 97 chevy silverado tranmission
Will it physically fit? yes. Will it be a direct replacement any everything hook right up and plug right in? If we are talking about an automatic then no. 1994's wiring was completely different than the 1997. Can it be made to work? possible, but I believe it would be more trouble trying to make it work than if the correct transmission were located and installed. If it is a cost issue where he has a good trans out of a 1994 he might see if a salvage yard will do some partial trading for the correct trans.
Apr 24, 2013 | 1998 Chevrolet C1500
What models auto transmission will fit in a 1995 chevy kc 3500 hd truck
1995 Chevy C3500 Pickup Transmission is an automatic or a manual transmission; 4x2, Excluding 3500 HD; gasoline, 5.7L 145K, 4X2, 4L80E (OPT MT1) NR, etc. There are many used 1995 Chevrolet C3500 Pickup Transmission available at
Programmateur De Calculateur
Dec 07, 2012 | 1999 Chevrolet 3500
I have a 91 g-30 chevy box truck with a 4l80e trany bad will any 4l80e fit or only 1991 4l80e trany.
Your best bet is to call the salvage yard and they can tell you what years will work on your vehicle.Hope this helps.Good luck.
Mar 11, 2011 | Chevrolet G30 Cars & Trucks
Will a 1994 chevy 4l80e 4wd swap into a 1995 GMC
Yes they will swap out nicely, the years where they made the change is in 1997 and the only difference is the transmission end housing has a different bolt pattern but has the same internal parts. You may also want to swap out the servo's with a corvette servo. The cost is around $45.00 and can be done without dropping the transmission pan, this will make your transmission shift firmer and will have less clutch slip[ between gear shifts. Good luck and hope this information helps.
Aug 19, 2009 | 1995 GMC Sierra
Can i use a 96 4L80E transmission in a 2000 Chevy Express Van
that trans is a little to lite duty for a diesel, u can use it but u will need to install the computer and the correct wiring harness.
Mar 01, 2009 | 1995 Chevrolet C/K 2500
1995 chevy 1500 4x4 pickup 4L60E trans
here is a place to call that sells only GM parts and they will also let you know what will fit your truck Schram auto and truck parts 1-800-292-1032
Feb 20, 2009 | 1995 Chevrolet K1500
What tranny
Your truck was equipped with a turbo 400. Look at pan and shape to determine trans. Square will be 700R4 , long to the rear will be 4L80E but this trans. requires computer.
Jan 01, 2009 | 1988 Chevrolet C/K 3500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
690 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
