Question about Bissell Flip-It Select Hard Floor Cleaner - Volcanic Satin
Eureka model 4335 - belt removal (top cover)
How do I remove the top cover of a Eureka 4335 so I can replace the belt?? I did not see any screws on the top or bottom.
  • sconvertino Mar 24, 2009
    motor runs, brushes dont turn, is belta busted? how do I get to the belt.
  • 389 Answers
Hi.  There are 16 different models of Eureka 4335, and frankly I don't know how much difference there is between them.  You can download a copy of the user manual from the website below.
If that doesn't work for you, please re-post - stating exactly which model you've got, and I'll guide you through it.
Good luck. If this has helped, please remember to rate me!
Posted on Feb 21, 2009
Loosen two screws on either side on top of the housing lifts off the top. exposing the roller and the broken belt.
Posted on Mar 25, 2009
Need to replace belt in eureka envirovac model 4470
You must remove the screws that hold the top cover onto get to the belt. Remove top cover then remove brush roll to install new belt. Replace belt at least twice per year for proper cleaning.
Oct 26, 2013 | Eureka High Filtration s Mighty Mite...
On our eureka world vac 9834 we cannot figure out how to remove the roller so we can put a new belt on
On this particular model the TOP cover is removed. There are 2 phillip screws near the roller and 2 tabs near the back wheels (push in with a flat screwdriver while pulling apart). Pull the hose through cover for easy cleaning. Everything I watched or read were for other models, where the bottom cover was removed :-(
Feb 10, 2011 | Eureka Boss 7601 Bagged Upright Vacuum
How do you replace the belt on the Eureka 4495A Upright?
hi there,
on this model there are 2 screws on the top of the unit just above the brush as you are looking at it.
Remove the 2 screws there and the top cover should come off.
There is also a black and yellow sticker under the top cover near the belt that describes in detail on how to change the belt there. Once that is done line up the cover and put the screws back in.
Good luck .
Nov 19, 2010 | Eureka 4495A Bagless Upright Vacuum
Eureka Fantom Thunder 12V/older model Need instructions on how to change belt and headlights.I could only find 1 screw on the bottom plate none on top plate. Thanks N J
there are two screws on the Fantom Thunder (It was not made by Eureka though) on the back of the unit just above the rear wheels. Remove these two screws and the top cover can be removed to get to the brushroll, belt and headlights. I believe the light bulbs in this unit are 12 Volt, not 110 volt.
Jul 18, 2010 | Vacuums
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I want to replace the belt on an upright eureka vacuum model 4481, any ideas?
I just replaced the belt on my 4481. Very simple. Be sure unit is unplugged. Unlock handle and let it lay down. Remove two screws on plastic cover. I purchased my belt at target for 2.54. Part number anywhere is Eureka U. Remove the roller brush. Loop belt around drive motor first and then around roller brush inserting the roller back into place belt side first. Replace cover and your ready to go. 10 min fix.
Jun 08, 2009 | Eureka Whirlwind 4481 Upright Vacuum
Changing belt - Eureka Whirlwind 5740
I tried the website for manuals but no luck. I called the toll-free # 1-800-282-2886 and got a rep right away. I gave him the model and s/n (lower bottom on the back side) and he walked me thru it. For the model I have, there are 3 screws to remove - With the vacuum upright and standing facing it - there is on on the right and one on the left of the bottom cover and one on the left side near the hose intake. Remove those to get to the belt. I ordered the belt with him too - althought the belts were cheap ($2.99 for 2) the shipping was $8. If this didnt help - call the 800# - they were great.
Dec 08, 2008 | Eureka Whirlwind Litespeed 5740 Bagless...
How do i replace the fan blade assembly which are broken in my ureka model the boss thank you lorne
Generic problem for all Vacuums
Posted by lmurray1 on Apr 23, 2008
How do i replace the fan blade assembly which are broken in my eureka model the boss
thank you
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 different models of the boss by Eureka – there is a standard old style upright that the belt that the belt would unscrew from the bottom of the motor and you would have to remove the top of the vacuum cover to remove the main motor and gasket assm, and then the fan has a reverse thread on the plastic fan and you would unscrew the fan after removing the belt pulley. Then you would screw on the new fan, belt pulley, replace the gasket and re-install the motor. If you have a new style with a side mount motor you would remove the top cover, the motor would be in there sideways, un-screw the motor, remove the silver tape around the fan housing and un-screw the fan housing – same as above un-screw the fan from the motor, there is a nut on the end of the fan holding that on – (remember, the fan has a reverse thread) re-install the fan. Then the fan housing, replace the silver tape, and then screw down the motor and replace the top cover, then you can test. As always free to contact your local vacuum dealer in your area in the yellow pages or contact your Eureka factory manufacturer listed below: Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
Changeing belt
On the top nozzle, there will usually is 2 screws holding the top done. There are slots or holes on each side near the front and the screws or in these holes. Remove them, remove the top cover and then you can get to the brush roll and belt.
Dec 22, 2007 | Eureka 2991AVZ Bagless Upright Cyclonic...
Bissell Flip-It Select Hard Floor Cleaner - Volcanic Satin Logo
954 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
