Question about Kenmore Elite 45986 Front Load Washer
My front loader doesn't use enough water.
We can't get our cloths clean because the washer want fill with water. It's leaving soap in the cloths even if we add extra rinse cycles. We have been using the Tide 2HE the same soap that came packed with the machine. We have reduced the amount of soap that we use to two tablespoons and we still have dried soap in the cloths. We proved this by washing clean cloths without adding any soap to the machine. It filled with suds even though we didn't add any soap.
We've tried adding water to the machine through the soap despencing drawer through each wash and rinse cycle and the machine will work ok when it has enough water. Even the bad smell is gone now that we've done this for awhile but this takes too much work to monitor the machine and add water manually. Can anyone tell me how to make the machine use more water? We have been filling our machine to the bottom of the indented portion of the glass door and it works fine this way. Our cloths smell fresh again and there is no more foul smell coming from the washer!!!
Tim
  • 15,935 Answers
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
The smell that comes from this machine is terrible. My clothes also smell bad. I wipe out the seals rubber around door and leave the door open for at least 30 min. After each wash. I also take clothes out...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Jun 19, 2010 | Samsung WF337AA Front Load Washer
Our front end loader stinks and we have to leave the door open. We have the exact same problem where I work. How do you get the smell out?
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 21, 2010 | Kenmore 44042 Front Load Washer
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Lg front load washing machine does not seem to get the clothes clean. I think it is because it uses so little water??? How can it get clothes clean with just a few cupfulls of water? All controls and...
I have run into this problem several times with LG washers. On one job LG had us replace every electronic componet that had anything to do with the water fill and the problem still was not resolved. The electronic control determines how much water to fill depending on the load size, so smaller loads give you less water, with the same amount of soap. Leaving clothes in the washer overnight, and leaving the door closed does contribute to mold and fungi growth in the washer. The customer tried different brands of soaps and different amounts of soap. He left the door open after usage to allow the unit to dry out, and tried different cleaners, to clean out the sludge build up. We determined that there just is not enough water to thoroughly clean the clothes. The sales store had to replace the washer with another brand. There is an ongoing class action lawsuit against Lg for this problem. Do an online Search for lg washer lawsuit. By the way, we don't have a problem with clothes not getting clean with the Whirlpool Super Capacity Duet Front-Loading Washers. Good Luck, Appliance Specialists
Jan 04, 2010 | LG WM1812C Front Load Washer
Mold and mildew in door deal of LG front loader WM
Barb,
This is a problem with all front loaders. We have used those cleaning tablets in a regular hot cycle per the directions on the box. You can also try placing 1 cup of crystal dishwashing detergent in the tub and fill the soap dispenser with bleach and run a quick cycle full hot.
Aug 09, 2009 | LG WM-2277HW Front Load Washer
Front loading washer leaves stains
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Nov 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Odors on the clothes after washing in Maytag front loader
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
Oct 23, 2008 | Maytag EPIC MFW9700S Front Load Washer
Front loading washing machines
not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
Mar 18, 2008 | Admiral AW22 Top Load Washer
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
LG front loader not filling properly
You have to remove the top of machine to have access here. Plug off the wall; you need a grip plier to loosen the clip to see what is blocking the hose.................refit carefully & firmly.
Nov 03, 2007 | Kenmore 44102 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
293 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
