Question about Hitachi 61SWX10B 61" Rear Projection Television
I have Hitachi model 32UDX10SA that's only 5 yrs. old. Circuit City where I bought it has closed and my picture tint is turn red. I don't know how to get to the menu for the color and tint controlls and need to have someone walk me through this or let me know where I can find a TV repair person in my area. The Cable man didn't know how to do this either. I have a HD TV and box so will need someone experenced in this as well.
  • 8617 Answers
SOURCE: hitachi projection tv way too
I would need the model number in order to help you out with the problem. Please respond to this post with your model number.
Posted on Jul 13, 2008
  • 4 Answers
SOURCE: Hitachi 43FDX11B television Ghosting
I had the same problem on my Hitachi rear projection TV 53FDX20B made in Mexico. The blue convergence problem. Blue focus had shifted and appeared like a blue ghost image. I followed the step by step intructions from the fixya site. First Replaced the two STK 392-110 ICs and turned on the tv. No change. Then I went looking for the bad resistor. There was one resistor RK50 (2.7 ohm, 1Watt capacity) which is attached not right close to the printed circuit board surface but was well raised up from the board. The bands on the resistor were a little discolored. I replaced that one and turned on the tv. The convergence problem was solved. Thanks for the step by step instrucitons on your site.
Posted on Aug 12, 2008
  • 74 Answers
SOURCE: Just purchased a RCA universal
if you just bought it it should have a list of codes
Posted on Sep 22, 2008
SD Tech
  • 14553 Answers
SOURCE: hitachi 53fdx20b picture is red
This is a set first made in 2002. I have seen a few of them with too much red.
Most likely what is wrong is the RED SCREEN CONTROL. It is located behind the front grill assembly at the front of the set. Screws usually secure it from the back on either side and then it pulls off--held by pegs usually.
Behind it is an inspection plate with several screws. Behind that is a BLACK block about 3 inches square with six controls(everything is black) One row of three will be marked FOCUS--stay away from those. The other row will be marked SCREEN.
With a flashlight you will have to look closely at the two rows of controls--they will have r,g,b marked next to them. (red, green, blue)
If you go to a Black and white program and the background is redish etc--take the set to a unused Video input2_bing.gif and after you locate the RED SCREEN CONTROL turn it slowly (less than 1/8 of a turn) to the left---the idea is to adjust just until the screen does not show red---on a blank input it should be black.
Double check it on a Black and White program and then if it was the problem the color should now be normal.
These sets did have some problems with that Screen /Focus block going bad--the entire block costs under 25 dollars and all the wires on the back of it plug in; if you have to keep adjusting it over a short period of time replace it or live with it.
I do this here for free so if this has helped you rate this solution as I do this here for Free.
Posted on Nov 30, 2009
  • 8457 Answers
SOURCE: Model# 53UDX10B bought in 2002. The green color
The tv have a problems known as a convergence problems,it dead.The tv have colors R,G,B lines mis alignment,have colors shadows or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Posted on Oct 11, 2010
Hitachi projector cp-s318 and the pictures give off a red tint.
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have). Go through the menu settings of your projector.
Hope this helps
Apr 01, 2010 | Hitachi CP-S318 Multimedia Projector
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
Dec 23, 2009 | Hitachi 57F710 TV
Hitachi 43FDX15B has a red tint...
This can be caused by a few things. The red crt/picture tube is going bad, which it would have to be replaced, tube can cost anywhere around $195 and up, if it is available. Another problem can be a bad transistor or IC on the red crt circuit board. Either way it should be taken to a repair shop. The average cost for repair could be over $300.
May 26, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Sound, but black screen
you have lost the video, either because the vertical section or the deflection circuit stopped working. if the power supply is independent from the others circuits is going to work and the video does not
Aug 06, 2008 | Hitachi 32UDX10S 32" TV
Hitachi projection tv way too much red tried the color control and tint no luc 1and 1/2 yrs old
Jul 13, 2008 | Televison & Video
Hitachi won't replace
I had the same problem a red halo that eventually led to complete discoloration. I called Hitachi and they had their local rep come out and look, they said it would cost $400 to install $1500 new light engine. Then a couple of months ago, I read a post on this site (Varian - Feb. 14, 2008 - suggesting Hitachi Customer Relations at 800-654 7013 was providing the light engine without charge).
So, I called them again and was not able to persuade them to cover my Hitachi LCD projection (50V500). It appears Hitachi has a poor record with their Light Engine as well all of their new generation TV. They have since stopped selling the LCD projection, but they are into plasma and LCD TV and likewise do not seem to have a good track record - as I hear from other users.
I did the smart thing and switched over to a Sony XBR4 Bravia 52" LCD TV 1080p HD at a reduced price (Approximately $2800 from!). My Hitachi cost me about $ 3600 at a Circuit City Store. Therefore, no Hitachi products for me and not from Circuit City, since, Circuit City asked for $4000 for the same Sony TV, I bought from Amazon, which included delivery and installation. Circuit City would add another $80 for delivery.
HITACHI really sucks!!! Put these people out of business!
Apr 24, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Esa television model PDP4294lv1 Has Red appearing in the screen. We're tring to find out how do we ge rid of the redness it actually takes over the picture and your not able to see anything. We also want...
the problem you are having can be fixed with an adjutment that has to be done on the power supply. you will need a thec to do this adjustment. as for the remote you can get them here.
as for the extended warranty if it is still under manufacturers warranty you should be able to get it from the place you purchased it from( if they offer it) or the manufacturer.
Feb 12, 2008 | Televison & Video
Hitachi 43fdx20b
well i had the same t.v. and u will have to set the picture tube which is really simple it ight seem hard but if you need an hand give me an call 1-403-362-2560 and ask for jason
Dec 17, 2007 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 51inch Projection
Wait until warm and try Magic focus
Dec 07, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 61SWX10B 61" Rear Projection Television Logo
97 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
