Error in Oce 9400 Plot Director Win 2000
When trying to edit settings within Plot Director I was getting an error that read, ''Error in file sender module.'' I uninstalled and reinstalled the application and when setting up a printer for the first time within the app I get that same error and then kicked out of the application. Any thoughts?
  • apace Mar 11, 2009
    me too face the same problem with windows xp
    can anyone help ?
There are a few possible solutions.
First, only the last version of Plot Director (3.4.3) works in Windows 2000, so make sure that is the version being installed.
Secondly, once PD is installed and uninstalled all registry references must be removed before attempting to reinstall or you will encounter errors.
Third, make sure you have Administrator privileges when installing or editing the program.
Last, because there has been no development on PD since 2001 it may be having issues with security, such as the ability to edit files that are in a protected zone or communicating thru a firewall.
As a test make sure that none of these programs are active during installation or configuration.
Posted on Mar 03, 2009
Oce Colorwave 600ps errorcode 16702 what does it mean?
The media output sensor didn't detect the media in time.
Ensure that you are not pulling your plot out before the CW600 actually delivers it. The CW600 stops printing, cuts the plot, delivers it to the top delivery tray, but pauses for a second before fully delivering it to the tray. See if you get the same problem if you output to the rear. If this problem persists, please call an authorized Oce/Canon service representative.
Apr 06, 2017 | OCE Office Equipment & Supplies
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ... > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Oce Plot Wave 300. What does error 22701 mean?
The cause can be trying to place new programs over old one that aren't fully uninstalled or malicious software.
Scan and repair any missing or damaged window registry files use RegCure Pro
maximize and eliminate use spyhunter
Jul 25, 2015 | Office Equipment & Supplies
I have an Oce Plotwave 300 giving 22529 errors. Have replaced the spider board and usb cables. Any suggestions ?
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
Jul 31, 2014 | Oc Plotwave 300 Developer
Why am I getting the error code 22550
It would be helpful to know the exact model number of your printer and the software level. If this is a PW300, it is an Initialization Error. Something is out of place that is not allowing the printer to start up properly. Opening and closing the lids may temporarily solve the issue but if it keeps on returning without having jams, there is either a sensor problem or the code level may need to get upgraded. New code levels have fixes that prevent false jam indications.
Jun 24, 2014 | OCE Check Plot Bond Paper, 20 lbs., 34" x...
Error message invalid dimensions
INVALID DIM error message may occur if you are trying to graph
a function that does not involve the stat plot features. The error can be
corrected by turning off the stat plots. To turn the stat plots off, press
y , and then select 4:PlotsOff.
Jan 19, 2012 | Texas Instruments TI-84 Plus Silver...
Error code "0813"
wath is Error code "0813" oce 9400
Sep 01, 2010 | OCE 3140 Copier
AVG Free install fails
Install AVG8.0, it should fix your problem
Feb 10, 2009 | HP Pavilion dv6000z Notebook
Oce 9400 error code 0501
Well, error 0501 is low toner concentration problem
fill new toner and then off and on main switch many time, if the problem persists then you need to check the toner motor.
Good Luck!!
Jan 12, 2009 | OCE 3140 Copier
Oce7050/error code 2205
what is oce 9400 error code 0813 ?
plase help me??
Dec 20, 2008 | OCE 3140 Copier
444 people viewed this question
