Question about Infinity Reference 1052W Subwoofer - 10" Dual 4 Ohms Polypropylene Cone Butyl Rubber Surround Car Speaker
Blown sub, butIdon't know why
My Infinity Reference 10" 1052W blew about a week ago. It was in a small enclosed box with roughly 170W x 2 channels x 4ohms pushed through it. I used 2 channels, 1 on each coil. The speaker was not torn and when I push or pull on the speaker cone, I hear bass. If it just sits naturally, it doesn't work. Can someone tell me if it is repairable or what may have caused it? Thank you.
  • 50 Answers
If you use a right channel on one coil and a left on the other different frequencies are going in different directions in each channel thus blowing a coil or badly damaging it-z
Posted on Feb 21, 2009
I have a kenwood excelon xr-4s amplifier and in channel 1 and 2 i have front speakers, in 3 and 4 i have a infinity kappa doble coil 4ohm each coil. When i turn it on loud it shut down the amp and start on...
Since you have two dual 4 ohm voice coil subs, hopefully you had one sub wired in parallel to each channel separately (one sub on 3, one sub on 4). That way, each channel gets 2 ohms. If you have both subs bridged across channels 3 and 4 (left + and right -) then you have applied a 1 ohm load to your amp, which would cause the problem you're having. It's possible the amp has been damaged, but the fuses on the amp should have blown to protect the amp. Check your sub wiring to make sure you don't have a 1 ohm load bridged across channels 3 and 4. Also check the fuses on the amp itself to make sure neither of them have blown. If everything is fine there, check your fuse under the hood that's connected to your battery. That fuse could have also blown.
Nov 14, 2017 | Car Audio & Video
Hi i purchased the bnps102 woofers and used them for 2 weeks i really enjoyed them and i also purchased the pyle 1400 watt amp and a jvc deck along with the boss amp kit installation now the speakers about...
If the lights on your sub box aren't coming on it's either your ground of power wire came loose or the transformer blew. As for the subs, make sure all the connections are good, especially on your RCA wires. If your amp is getting power, then check your speaker connections. Also, make sure to turn the gain know up. The gain knob is located next to the RCA input on the amp. Let me know if this helps.
Aug 21, 2011 | Pyramid BNPS102 Car Subwoofer
Have SONY Xplod 1000watt dual ch. amplifier pushing two 12" MTX Terminators. About a week ago my my Sub on the right side quit working, while the left side sub is still banging hard as ever. I...
Check your subwoofer for resistance. It is more likely you blew a sub than a channel on the amplifier. If your subwoofer has no resistance, which can be checked using a multi-meter, then it is blown.
Jan 17, 2011 | Sony Xplod XM-1652Z Car Audio Amplifier
Need to know how to wire my system ...I have the infinity reference series 611a I was told it was a mono block but it has two channels on the exterrior...also I have two 12 inch MTX thunder dual voice coil...
it all depends on what kind of box the mtx subs are in as far as wiring the subs. The best way would be take the speaker wire from both sub boxes and run the positive into the right positive then the negative into the left negative. and run 8 gauge wiring kit to the amp because 10 might be to small and 4 is to big 8 gauge is perfect for this amp.
Jul 18, 2010 | Infinity Reference 611a Car Audio...
Subwoofer buldging out problem
When speakers are wired in the wrong way the will do the "pushing out" you're describing. Basically the polarities have been reversed and if kept like this over a period of time will blow the speaker. Best thing to do is to disconnect the power by the negative on the amp and take out the fuse from the power supply. Check the wires running from the amp to the subs, negative to negative and positive to positive. I know it sounds basic but many people do mix it up! I would also check to see what channels the subs have been wired into?
Best way is to have one sub from channel 1 and the other sub from channel 2 for example. Or if its a bridged 4 channel amp, have 1 sub running from channel 1&2, and the second sub running from channel 3&4 still making sure of the polarities. Again this all depending what kind of amp and sub you have.
For example;
A 4 channel (bridged) 1000W amp. 250W max per channel or 500W per 2 channels! So if you have 2 500W subs, by connecting one to a single channel will decrease subs ability due to the lack of power supplied. However by combining 2 channels you optimize the output!
Once you know all your wiring from your amp to subs are ok/good connections/good wires etc you shouldnt have to "wiggle the wires" to get it to work as this is just a bad connection. Also ensure that no 2 wires are touching. Make sure that the master volume on the amp is turned down. You dont need this to be on loud at all, in fact far from it or you'll risk damaging both the amp and subs!
Hope this helps!
May 27, 2009 | Car Audio & Video
Thunping coming from subs when car is turned off.
2 things to try, one. run your RCAs on the opposite side of the car as the positive wire. if you still hear the thumping try changing your RCAs. if you still hear the thumping, try a different anp or head unit. if you still hear the thumping, your subs are blown. best of luck
May 08, 2009 | Infinity Reference 1300a Car Audio...
Infinity Entra Sub 150 no sound or power
I had the same problem. When I opened it up, the fuse was blown, and it was a pain to find the fuse it needs (3 Amp, 250 V slow-blow fuse, 5x20 mm). Also, the 2 large electrolytics (big purple things near the amp) and one small capacitor were all blown. For 4 fuses, bought seperately from, and the 2 electrolytics and 1 capacitor, it cost about $20, plus almost 20 more in shipping, which still isnt bad considering the original price of the sub. However, the tricky part is that you have to know how to use a soldering iron to take out the old components and put in the new ones.
Jan 01, 2009 | Infinity Entra Sub Subwoofer
1211a amplifier
if your amp. work in bridge you can attach + 1st channel and + 2st channel to your sub woofer. by series 2 ohm you have 4 ohm sub woofer.
Sep 26, 2008 | Infinity Reference 1211a Car Audio...
Subs cutting out
Agree with Kev. Even if the woven lead wire looks ok, it can still be bad. I unsoldered it, clipped a lil from both ends, and re-soldered it. Works great now.
Sep 11, 2008 | Infinity Reference 1230W Car Subwoofer
Protect light flashing/ticking
this problem sound like you have too low of power going to your amp, test your battery and make sure its putting out enough power for at least the mininum amount of power that your amp requires, you can find that information in your manual or sometimes they post it on the amp itself. i hope this info helps
Oct 08, 2006 | Infinity Reference 1211a Car Audio...
Car Audio & Video Logo
308 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
