Question about Whirlpool Duet GHW9150P Front Load Washer
Washer goes right to drain when started
We've had our Whirlpool Duet for almost 3 years and this problem just started. We thought it was the pump (F21 error), replaced the pump, still getting the error and the washer goes right to drain cycle when started.
Thanks
    President:
  • Whirlpool Master
  • 2,651 Answers
This error occurs if the touch-pad/LED assembly is not
able to transmit/receive data to/from the central control
unit (CCU).
Possible Causes / Procedure
1. Check the touch-pad/LED assembly by selecting
different cycles and changing the modifiers and
options available to confirm the touch-pad/LED is
responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit
(CCU).
Posted on Feb 21, 2009
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool duet front load washer is giving a F21 error code. It will not drain. When I blow into the drain hose on the back of the washer it will start draining. But everytime I run a new cycle it will...
whirlpool duet front load washer this video is on a bosch but it will help you Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet front load washer. the spin cycle did not complete and their's water still left inside. i've tried to shut off the washer and restart it, it will spin once and then stop...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer (model: wfw8300sw02) partially drains. Clothes spin out as dry as ever, but 2-4 cups of water are always left in the filter/pump. I've 1) emptied the filter 2) disconnected...
puzzled here because there is always some water left in machine this is normal .you are quite right when you say that when you take the drain hose out of stand pipe and lower it water comes out but that is because of gravity .
Jun 07, 2011 | Whirlpool Washing Machines
Duet GHW9150P Front Load Washer: Whirlpool Duet Washer - Error F21 (What is this) ...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9100 will not drain during regular wash cycle. Cleaned drain filter & ran diagnostic and then rinse & drain. Water drained from washer & clothes were damp and I thought the...
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have had my duet for about 5 years. I thought
The problem is commonly caused by debris building up in the drain pump. Over time it sours and begins to smell. The following link explains how to access the drain pump and clean it:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
There are several other factors that can also contribute to front loader odors. The following link explains a things to look for and try:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Read through the information provided and let me know if you have any questions. I hope you find this information helpful.
Jan 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Feb 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
