Question about Mitsubishi WD-52725 52". Rear Projection HDTV
My Mitsubishi tv will not turn on.
It is a 52" (I think) DLP that I bought approx 4 years ago. There is a small light under the word "Timer" that keeps blinking very quickly, but the power will not come on.
  • 1 more comment
  • bobbyvee Mar 06, 2009
    have a WD - 52725 flashing green timer light, doesn`t turn on
  • jaymebenson Apr 18, 2009
    same thing just happened to us
  • telcomqueen Apr 21, 2009
    The flashing timer light on my Mitsubishi WD 52525 wont turn off and the TV wont turn on. Have tried to reset and unplug...help!
  • 4,234 Answers
If you have the owner's manual, you will find that the blinking light is an indicator that the lamp or fan is the problem. I'm not sure of your model number. Can you confirm that model please? If you no longer have the manual, once you confirm the model number, I can look up the code for you. Given its age, I would suspect that the lamp needs to be replaced.
Please post the model number and I will confirm.
Thanks,
Dan
Posted on Feb 21, 2009
  • Maciesmom217 Feb 05, 2011
    Lamp is new,wd-62525
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I bought a mitsubishi wd 52327 new several years ago. I've replaced the lamp once and it worked fine but now it needs to be replaced again. We bought a lamp off EBay w/housing. I installed it but the tv...
Hi Brent, Mitsubishi's have a problem with the power supply and the Light Engine which incorporates the Digital Module of which it has to be purchased as a complete assembly. I sincerely believe you should not put that kind of money into a dlp set. The cost of the light engine is in the area of $1100.00. Your last idea is the best one.
Mar 09, 2011 | Mitsubishi WD-52327 52" Rear Projection...
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
MY tv has a blinking green Light under the timer indicator
The DM is not completeing the boot sequence due to failed capacitors on the DM power Board. Very common problem with that model DLP. You can get the V26 DLP DM repair kit at the following link which has the replacement capacitors and step by step detailed instructions on how to do the repir. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Mar 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
DLP Lamp Replacement
yes it is in a cartridge and it is plug and play. and if 1 year old still under wtty. The dimness could also be your fluids??
Apr 01, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
532 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
