Question about Kenmore 62602 Electric Dryer
Kenmore dryer 400series electric not gettin hot enough to dry
I have a kenmore dryer 400series electric and
it not putting out enought heat to dry a load of clothes in just 1 cysle it take 4 time the dryer isn't even 2 yrd.old
    Problem Solver:
  • 19 Answers
You might have a open heating element. ohm out your heating elements.
Posted on Feb 21, 2009
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Sep 21, 2014 | Kenmore Sears Kenmore Clothes Dryer Flame...
Kenmore gas dryer series 500 won't heat
Thermal Fuse
Air Flow and Heat
Warning
Jul 04, 2014 | Kenmore Elite HE4 Electric Dryer
The heating is not working properly, not hot enough. I tried 3 hours, but the clothes still not dry. It is a 120V Kenmore dryer.
IF THIS IS AN ELECTRIC DRYER 110 VOLTS ISN;T RIGHT 208 VOLTS SHOULD BE MORE LIKE THE ANSWER. IT TAKES 208 VOLTS TO RUN THE HEATING ELEMENT AND 120 VOLTS FOR THE MOTOR
SOMETHING DOSN'T SOUND RIGHT THERE
Feb 06, 2011 | Kenmore Dryers
My Kenmore 400series 6942 electric dryer works, but doesn't get hot. Pulled the heating element had it tested. It shows good. Had three other relay/fuses tested. They show good. It has to be easy enough...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpg if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
Jan 20, 2011 | Kenmore 400 6942 Dryer
Dryer is not heating enough and it takes too much time to dry clothes. I checked the vent duct to outside and it is ok. My dryer is old but it is in good condition. It pays to repair it.
The problem could then be with the thermostat... it is not allowing the heat to be hot enough...
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 21, 2010 | Kenmore 76832 Dryer
My Kenmore dryer does not get hot enough to dry a load
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you have no kinks or clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the door opening) and let me know. I hope you find this information helpful.
May 31, 2010 | Kenmore 62802 Electric Dryer
Not heating/drying....I am sure the heating element probably needs to be replaced...which I can do myself if I can get the part and figure out where it is....400series
remove the back and check the heating element inside the heater box and the heater box fuse on the left side top of heater box
May 05, 2010 | Kenmore 62602 Electric Dryer
Our Kenmore electric dryer does not get hot
By the nature of your question, I'm assuming the dryer IS heating, but just doesn't get hot enough. If you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before assuming you have a malfunction with the dryer:
The number one cause of dryer heat related problems is caused by poor exhaust ventilation. If the dryer can't breathe it will not dry efficiently and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
If you still have problems, please post back and let me know. I hope this helps you.
Dec 22, 2009 | Whirlpool LER5636P Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Kenmore 62602 Electric Dryer Logo
365 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
