Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
What size is the kenmore coldspot 59532990 - Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Kenmore coldspot refrigerator 106.9555711, serial SF 1317588. What is the cubic feet?
The third digit after the dot usually provides the refrigerator's capacity. This suggests that the 106.9555711 is a 25 cu. ft. refrigerator. If this is an apartment-sized fridge, then it may be a 15 cu. ft unit instead.
I hope this helps.
Aug 20, 2017 | Kenmore Refrigerators
Kenmore coldspot model 106.58902800 ice maker does not dispense ice
Ice maker will not dump ice, makes it but will not dump ice.
Jan 30, 2012 | Kenmore Refrigerators
I'm having problem connecting copper water supply line to back of fridge. The ferrell on the copper line seems to be preventing the nut from comming down onto the connection point. The refrigerator is a...
I had this problem. Try a different ferrel and/or cap. Some ferrels are of different sizes in thickness, for some reason. Some ferrels are thicker or taller. Some caps are shorter than others. Good luck.
Jul 07, 2009 | Refrigerators
Blowing out air but not cooling or freezing /kenmore coldspot
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts.
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Jun 10, 2009 | Kenmore 60721 Refrigerator
What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
Dec 12, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
273 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
