Question about eMedia Music Corporation Piano And Keyboard Method for PC, Mac
I've started up Elektrik Piano 1.5, i've connected the usb'keyboard. Turned it on in Elektrik piano midi controller menu as input device. When i click on the tangents in elektrik piano with my mouse there movement in elektrik piano and sound, when use the tangents on my keboard it hows movement in elektrik piano, but there is no sound.. Anybody know why?
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Make sure you follow the steps of the procedure below exactly. Connecting incorrectly can make data
send and receive impossible.
Turn off the digital piano and then start up
your computer.
• Do not start up the music software on your computer
Turn on the digital piano.
• If this is the first time yo
u are connecting the digital
piano to your computer, the driver software required
to send and receive data will be installed on your
computer automatically.
Start up your computer's music software.
Configure the music software settings to
select one of the following as the MIDI device.
Apr 19, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
Midi settings
You have to plug in the laptop sorry to say. Think of it as a piano that can be used as a midi controller.
Jan 29, 2012 | Williams Allegro 88-Key Digital Piano
I'm in the studio using LogicPro with my MO8 -
In General MIDI, the grand piano is defaulted to MIDI channel 1.
IF you have a device that responds to "General MIDI" format, just send the MIDI data to channel one and you should be fine. Remember that pianos are VELOCITY controlled and usually don't use after touch so you have to generate appropriate velocity for EACH note if you are using an editor.
Jan 07, 2010 | Yamaha Music
Need help connecting Korg C-303 (Concert Piano) and Korg Symphony Model O3 (Orchestra Module). Have no documentation for the Symphony module.
Assuming the C-303 has a MIDI out, connect a MIDI cable from the MIDI output of the C-303 to the MIDI input of the symphony module.
Connect two audio cables (mono 1/4 inch) from the symphony module to a suitable audio amplification system OR possibly into auxilary audio input jacks of the C-303, if they exist.
I have a Symphony module but not the piano you have and I have mine connected to a Yamaha organ.
May 12, 2009 | Music
The piano wizard software won't recognize keyboard
you should go to your  utilities --> audio midi setup and make sure your system is recognising your midi device. Play around with your midi settings, see if you can get something going.
Otherwise the problem maybe with the software clashing with Leopard. Double check on the manufactures website that their software is compatible with 10.5.6, or they may have an update for you.
Thirdly you could check if you keyboard is working correctly by opening garage band and making a new software instrument track, press record and see if you get any thing.
Good Luck hope this helps.
Mar 22, 2009 | Wizard Publishing Piano Wizard PREMIER...
Transfer recording from technics piano model sx-pr602-m to comput
the correct way to transfer files from the piano to a computer is via the MIDI out socket on the piano ...not the jack
you may possible need a midi to usb convertor ...which readly available and cheap
Feb 01, 2009 | Music
Midi keyboard sound quality bad
you are likely running it thru a soft synth. Check the help files there is a section in there on "using soft synths" that will explain it more fully. Plus a usb connection can sometimes be problematic (not always). But the tutorial in the help files will tell u how to use the sounds from the piano instead of the MIDI sounds
Dec 17, 2008 | Cakewalk Music Creator 4
Recording on my Yamaha CP33 keyboard using USB
We're talking about audio recording. If so you must conntect your piano by using the L + R outputs with your sound card or mixer line inputs (that's how I do this). USB is ok if you want to use your piano as a master keyboard (MIDI). Another important thing is that you must have an additional application installed called sequencer ( for example Cubase Sx, Sonar...) which will let you store your digital music. I'm not talking about the proper settings of them because it could take a day or so...:)
Overall, you will have to learn a bit about the home studio, home recording techniques. There are tons of informations on web. A great thing is that you can use your CP33 as a master keyboard to control additional virtual instruments (VST) or for example play different piano samples (check Synthogy Ivory). Possibilites are endless!
May 24, 2008 | Yamaha Full-Size Keyboard
Mac Driver for Dream Cheeky USB Roll-Up piano
I got one of the drum kits last Christmas, but I have a Mac. Finally, this Christmas, I got around to writing a driver for it. I mean, why not? It runs in Terminal and translates the drumkit hits to MIDI messages which you can use to control GarageBand or Logic or send out a MIDI interface to control MIDI hardware. Doesn't have any of the fancy learning modes or anything, though; just lets you play it. Email mail_ben_schmidt at yahoo com au if you're interested. I doubt it would take much modification to get it to work with the piano, which I expect works on exactly the same principles. But I don't have a piano, so I would need to collaborate with someone or have one lent or donated to me to do that.
Mar 07, 2008 | Computers & Internet
eMedia Music Corporation Piano And Keyboard Method for PC, Mac Logo
175 people viewed this question
Top eMedia Music Corporation Computers & Internet Experts
David Payne
David Payne
Are you an eMedia Music Corporation Computer and Internet Expert? Answer questions, earn points and help others
