Question about XFX GeForce FX 5200, Graphic Card
Poor Resolution on Monitor 2
I have Dell Optiplex 170L running XP Pro, a Geforce 5200 Card and 2 x Dell S2209W 22" Monitors.
The screen resolution on Monitor 1 is just great but the resolution on Monitor 2 is rubbish, all Windows appear stretched widthways so circles look like ovals. Both Monitor 1 & 2 are set up exactly the same on the highest resolution and all other settings are identical.
Monitor 1 is plugged into the VGA port and Monitor 2 is plugged in the DVi port.
HELP!!!
  • glyndelacy Feb 21, 2009
    Before I make the changes to the registry, is it possible that the Geforce 5200 cannot support 2 monitors with 1920 x 1080 resolution?
    If that is the case, should I install a second 5200 card so there will be one card for each monitor?
  • 23 Answers
What u can do is.... 1) Backup your Registry first
2) go to Regedit....Start>Run>Regedit
(this is assuming u have latest Nvidia driver's installed)
HKEY_LOCAL_MACHINE/Software/NVIDIA Corp/Global
In global. Make a new KEY called NVTWEAK
In this key, make a new DWORD value called Coolbits now, change the value of coolbits to 3.
Now when you do into Settings for GFX and advanced settings....you will notice a CLOCK SPEED/FREQUENCY tab. Change them.....go up like 20mhz....or 30 or 50...too high will screw ur card...too low isn't worth the trouble.
So, slowly go up little by little until you notice s--- on ur screen that's dodgy..then just fall back behind that Freq.
Also....another fan taking heat AWAY from the GFX card wouldn't do any harm either.
Don't forget to rate this solution.
Posted on Feb 21, 2009
  • Greg Caudle Feb 24, 2009
    Will, you could install another card, but this card is designed to handle two at the resolutions that are selectable.
    Remember, if you do chose to modify the registry, back it up to an external source.
Dell optiplex
Yes it can, if otherwise all you will need to do is to reduce / high the screen resolution for better image and display.
by right clicking on your Desktop , scroll down to properties (if window xp), screen resolution (if window vista or window 7) and click on slider to increase or reduce the resolution . then you are done.
N:B: if the montior of the higher resolution would not display, make use of a normal one that will work to set it first and later return your new 24inch monitor. IT WILL DISPLAY BETTER.
Feb 27, 2014 | Computers & Internet
Compaq fs740 text too faint and fuzzy to read well
Firstly you need to switch to the monitor's optimal resolution of 1024x768 @ 85Hz and before anyone posts anything about resolution 1024x768 @ 85Hz is the optimum not the maximum. To change to this resolution: Assuming you are using Windows XP click with the right mouse button an an empty part of the desktop and select Properties (or click Start, then click Control Panel then click Display), on the Settings tab, under Screen resolution, drag the slider bar until it says 1024x768 and then click Apply. Also in Display settings you'll find an advanced button, in the advanced panel you'll see the option to adjust the refresh rate, try adjusting this to 85Hz. Now press the Menu Button on the front of the monitor and press + of - until you see an option called "Degauss" and press the select button on the front of the monitor, your screen will do a disturbing jump and flicker accompanied by a metallic thud, this is normal. If this doesn't help message back.
Aug 26, 2007 | Compaq fs740 17" CRT Monitor
I have a dell Optiplex gx260. I bought a nice big Acer 23"monitor 1920x1030 but the max resolution in the graphics properties is 1280x1024 so I get a stretched screen or a poor resolution
jenny_beech
The resolution 1920x1030 is not a standard resolution. Also at the time this computer came out you did not have monitors this big ether. So you most likely will not be able to get 1920x1030 on this computer. However if you install the drivers for the monitor on the computer you should atleast get the right aspect ratio so you have poor resolution. You should have a CD with the drivers on in it. The llink below will show you haw to install them maually in Windows 7 if the drivers are not in an installer. Let me know if you need the steps for Windows XP.
How to install your monitor drivers in Windows 7
Issken
http://www.fixya.com/users/issken
Sep 30, 2010 | Dell OptiPlex GX260 PC Desktop
I have a Dell Monitor S2209W and it does not auto adjust when I change the resolution. It is connected to is a Dell PC running Windows XP. If I do not set the resolution to 1920 x 1080 the whole screen...
The S2209W is designed to be run at the optimal resolution of 1920 x 1080 http://support.dell.com/support/edocs/monitors/S2209W/en/ug/optimal.htm
selecting a lower resolution will result in generally unsatisfactory appearance. This is due to the hard wiring of the pixels in LCD screens.
What you can do to abate the text being too small is adjust the DPI setting from the default of 96 to 120, or even 144 if you need real large text
Oct 04, 2009 | Computers & Internet
Dell s2209w with a GeForce fx5200 blinks black
Make sure your refresh rate is not set too high. for the 192N it should probably be not much higher than 60Hertz
Jul 31, 2009 | XFX GeForce FX 5200, Graphic Card
LG 22" TV with Geforce nVidia 5500 FX 256MB AGP card
Try getting a new video driver. Foreware = motherboard drivers and such, not video.
I saw this driver on Nvidia.com
http://www.nvidia.com/object/winxp_175.19_whql.html
Its the XP driver for those 5000 series FX cards like yours. Try installing that and checking out the Nvidia Panel after.
1680x1050 is an odd resolution for TV, that is what normal 22" monitors have but I guess it will do up to 1680x1050 only when hooked up to a PC.
Feb 21, 2009 | LG 26LX1D 26 in. LCD HDTV
New graphics card, no picture
1. Try to start in SAFE Mode by press f8 while booting. If successfull.
2. Press F8 again select enable VGA mode and continue.
3. Your monitor is not supporting the resolution reduce and restart it will work fine.
4 To reduce the resolution desktop right click, select properties goto tab setting - reduce resolution
Jan 14, 2009 | XFX GeForce 6800 GT, (256 MB) Graphic Card
New Samsung 245/bw monitor w/native resolution of 1920x1200
1.The resolution 1600*1200 is very good. why you need it 1920*1200 ?
2. What kind of samsung monitor do you have ? If is it LCD ... It doesn't suport that resolution ..... Mine, for example, 720N , suports only 1280/1024 . 17" .
Jun 07, 2008 | Samsung Computers & Internet
Monitor Resolution
have you tried the newest drivers for your card?
Nov 30, 2007 | XFX GeForce FX 5200, Graphic Card
XFX GeForce FX 5200, Graphic Card Logo
229 people viewed this question
Top XFX Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
