Question about Husqvarna Chain Saw 20" Bar
Need to know what the carb adjustments are for a model 61 husky
  • 181 Answers
Low side one turn out from bottem.high sie is the same.after saw is running readjust both high and low.make sure the side dosen't go in any more then 3/4 of a turn out......if it does you will burn up the saw....
Posted on Feb 23, 2009
The sparkplug in my husqvarna 61 is always wet. Even after I dry it out it still gets wet,also my machine looses power.how do I fix this
My guess is you may need a carb overhaul kit. It sounds like the carb is flooding all the time which may only require a strip and blow out. The air and fuel passages in these carbs are tiny and easily blocked so a blast with an airline can usually do the trick. While you are at it, clean the air filter. There are small parts inside so strip on a clean bench and lay parts out in sequence. There is a small diaphragm inside which can get pin holes in it which is why I said get a repair kit. You don't need a dealer kit as such, just get the carb details and go online ebay etc if you don't have somebody local. Don't use an airline on an assembled carb, you will damage the diaphragm. There are only 2 makes of carb generally so go online to the manf and down load matching info to give you a guide. There's a great guide at www.saws.com search husky 61
Aug 08, 2014 | Garden
Chainsaw chain keeps running
This is a carb adjustment issue and needs to be rectified before using it again, the L jet on the carb is set too lean, if you cannot correct yourself i would suggest taking it to the local chainsaw shop.
Jan 19, 2014 | Husky Garden
Husky 61 lots of spark fuel is getting to carb cylinder is dry wont start would comprison be bad?
Two stroke engine have a reed valves, or something like it, that prevents exhaust pressure from causing the gas to back up.
Because of long idle times in the winter, if you don't use a fuel stabilizer, the gas dries up an leaves a sticky varnish residue.
This not only plugs up orifices, but glues the reed valve either shut or open. Either is bad. So you probably have to take the carb off and clean it to remove the varnish.
Aug 26, 2010 | Husqvarna Chainsaw Piston Kit for 61...
I need a drawing of a carburettor on a 61 Huaqarrna chain saw\r\nwhere do I get it? It is a husqvarna Chain saw
You didn't specify of its a 61 or a 61 Rancher. Here's the info you need to take to your Husky dealer. The diagram will be with the major repair kit.
Model 61, then the 61 Rancher:
CARBURETOR Model 61: ecblank.gif Tillotson HS-163A, B , HS-254A series or
Walbro WS series
MAJOR REPAIR KIT: ecblank.gif RK-23HS for HS-163A MINOR REPAIR KIT: ecblank.gif DG-5HS/T for HS-163A
CARBURETOR Model 61 Rancher: ecblank.gif Tillotson HS-163A series or
Walbro WS-17A, B series
K10-WS
D10-WS
May 18, 2010 | Husqvarna Garden
Carb assembling question
Thanks Jerry.
The only that came to my mind is to try here:
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did a quick search and saw nothing for a 61 carb but it does not mean it is not there. Someone at Arborists has rebuilt your carb. The hard part will be digging them out then dredging up the right memories. Good Luck. HTH Lou
Mar 05, 2010 | Husqvarna Chainsaw Piston Kit for 61...
I need to know the carb adjustments for a Husky 65. I need to know how far each screw should be turned out on the carb to get it to run so that I can fine tune the saw.
Start with 1.5 turns on the low speed screw and 1.5 turns on the high speed screw. You can fine tune from this setting.
Feb 03, 2010 | Plumbing
Hi how to put front spring in to clutch brake
No model 61 listed @ Husqvarna.
How about a 261 here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter 261 (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
See the Chain Brake Assembly detail. HTH
Lou
Oct 22, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Jul 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna Chain Saw 20" Bar Logo
244 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
