Question about Sony Playstation 3 (PS3) Console
No power to PS3
My son left our ps3 on all night and now it has no power at all. What can be wrong with it and is there anything i can do to fix it?
    President:
  • 2,653 Answers
If you get no led lights, red lights or anything then it's likely that you need to replace the power supply. It's easy enough for the home user to do. If it's under warranty still then by all means use it. Otherwise open up the PS3 (you'll need a special T10 Security driver) I think you can get one from Radioshack but I'm not 100% sure. All the other screws are normal phillps. Then you'll see your power supply, it's the big square box on the left. Check to see which one you have and then match it up with a replacement one on ebay. They go for around $50 if I'm not mistaken. Make sure you get the same one you had before, they're not all the same.
Posted on Feb 20, 2009
My playstation will not turn on ive tryd to use all the power points in my house and still not working can you pls help (ive left it unpluged all night and still not working when i turn it on)
hello. the most probable cause for a ps3 not turning on is broken power supply. my advice is to bring to your nearest sony service center. especially if your console is still under warranty. fixing it yourself might void the warranty. but if you still want to do it yourself buy yourself a power supply that is compatible with your console (40GB ps3=40GB ps3 power supply) here a link on how to open your ps3 http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm but remember, do this at your own risk. still the best way is to bring it to a service center. hope this helps
Apr 30, 2011 | Sony Playstation 3 (PS3) Console
I left my system on downlading all night got up this morning it turned on an off an said i turned it off wrong what do i need to do
Greetings Taleway48,
The ps3 prompts you with this message when you:
  1. Shut the Ps3 off using the switch located in the back of the Ps3.
  2. Unplug the Ps3 while it is running.
  3. The Ps3 overheats or has a technical problem.
You Ps3 most likely has had a technically problem. Although this sounds scary, it is of little importance and Will Not cause damage in any way, shape, or form. Continue to follow the on-screen instructions on your Ps3. You should be up and running in no time. If you need further assistance, please feel free to contact me. Thank you for using FixYa. =)
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
My son was playing his PS3 for an hour or so. I went and turned it off for him when he decided to leave the room. I pushed the ON/OFF button (on the left side of the TV) and realized I had the remote...
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Jun 15, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I downloaded PS3 system software update 3.15 last night. Now when i turn it on the green and blue lights come on and it starts to boot up but stops and there is nothing on the screen and my controller...
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. i had the same issue and this fixed it.
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
PS3 Guitar Hero World Tour with a PS2 Guitar
That is just so fucked ! I really would advice you to go back to the shop probably its packaged wrong.... Tell your son that the packagers are jerks :) ! I had a ps3 guitar and it worked , at the shop they will give it back directly.
Good Luck!
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3 not reading games or dvd's
hi!it looks like there is a problem with the laser mechanism which is now quite common problem,if its in warranty please call sony and request for a replacement..they should be able to help you..i had the same problem and my ps3 stopped playing any disc,i got it the mechanism replaced(no service for ps3 in India sadly)hope it helps!
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
PS3 Console Power
if you get no light at all anymore you may need a replacement power supply. Ebay offers a few, I have a working one for sale right now. it is fairly easy to replace but you need to open the console.
If the warranty is expired it won't make a difference.
If you still have warrantu send it in for a replacement.
Sep 27, 2008 | Sony Playstation 3 (PS3) Console
MY SON PUT A MAGNET IN MY PS3 NOW IT DOESN'T WORK. WHAT COULD HAVE HAPPENED AND HOW DO I FIX?
If it was a powerful magnet and was near the hard drive, it could have messed with that. Aside from the hard drive, I can't think of anything that would react negatively to a magnet.
Can you elaborate a bit on "doesn't work"? Does the red light come on when you plug in the power? Does video come up on the screen but the PS3 not boot? etc
Jul 30, 2008 | Sony Playstation 3 (PS3) Console
Disc wont coem out
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me. PLAYSTATION FAN FOR LIFE! waiting on PS4
Mar 09, 2008 | Sony Playstation 3 (PS3) Console
Ps3 controller
my ps3 controller wont connet with the ps3
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
