I recorded two programs one by timer programming and the other by one touch programming and I finalized the disc and have been trying to unfinalize the disc so I can use the disc again but I cant get to the disc menu. The title menu keeps coming up on the screen and I canot get to the disc menu when I go to setup. It will only go to General Setting or Recording.
SOURCE: Timer Recording
This is from the KR10 manual. Hope it helps.
1. Set the clock before setting a timer.
2. Insert a recordable disc with enough space.
Then:
1. Press [TIMER PROG] on the remote
2. Use up/down arrows to select "New Program" then press [ENTER]
3.Use up/down arrows to enter the date, then press right arrow
4. Use the arrow keys to enter the start and end time, then press right arrow key.
5. Use the up/down arrows to select the external input position to which your cable/satellite box is connected, then press [right arrow]
6. Use the up/down arrows to select a recording mode.
7. Press [ENTER] when all items are entered.
8. Press red [I/O ON STANDBY] to set a timer programming.
DO NOT FORGET THIS LAST STEP! The timers will not work if the recorder is not in standby mode.
SOURCE: HDD Corrupt
I have the XS35 and the HDD drive is curropt. Can I do the following?
1. Download the Toshiba firmware update:
http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=rd-xs34
2. Burn the ISO to a CD-R disc. ImgBurn is an excellent free burner for this.
http://www.imgburn.com/
3. Insert the CD in your unit. It will auto-install the firmware. Follow onscreen instructions. Takes about 10 minutes total.
After the update, my existing HDD shows are playable again, and I can record and playback from the HDD. I bet it would be a good idea to periodically backup your shows on DVDs, and regularly reformat the HDD.
Mike
[email protected]
SOURCE: Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
SOURCE: how to finalize a recorded dvd disc?
on the remote is there quick navi button (this will take u to the finalizing screen)
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
the message will be deleted automatically after reading by the recipient. snapchatapkdownload.com visible to your pals only for that time duration.
