Question about Thermador PRG364GLUS Gas Kitchen Range
2 left burners will not lite.Oven will not work now.
3 weeks ago 2 left burners stopped working. Red lite is on even with control knobs off. 2 right burners are working fine. When right hand burners turn on all igniters work. Two days ago oven was working during the day. At dinner time would not work . When you go to turn on oven red lite will go on and you can hear contact being made but no ignition. At no time trying to lite either the left burners or the oven do you smell gas. Thank you.
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: The oven isn't working and there is a gas smell coming from it.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Jun 12, 2010
heatman101
  • 43501 Answers
SOURCE: I tried turning the main
heatman101
Posted on Apr 16, 2011
  • 11800 Answers
SOURCE: Thermador PD36 dual fuel range
There is no PD36 model. There are several PRD36 models of electric/gas ovens and in all of them the gas supply is common to all the top burners - all the control valves connect directly into a manifold/main gas tube.
If you can't lit those 2 burners with an external flame it means that the supply of gas to them has been cut by a blockage on the manifold - it's extremely unlikely that 2 valves have failed at the same time or that the 2 safety wires to them have failed simultaneously . The oven will have to be dismantled and the case of the blockage found and removed - if necessary the entire manifold will have to be replaced. This is a very complicated job that requires extensive experience - most likely you will have to call a repairman .
Posted on Jun 01, 2011
Why would the left burner activate the right igniter?
Sometimes a lot of the holes in the burner get plugged. I use a toothpick to clean them out.
Hope this helps.
Mar 20, 2015 | Kitchen Ranges
Ceramic stove top knob not working
Are you referring to the spark, or the gas flame? Are you able to turn the faulty burner on low, and lite with a match? You most likely need the spark switch replaced. Pleazer Appliance...
Apr 19, 2014 | Kitchen Ranges
Our weber grill is suddenly getting too hot... even with only 1 of the 3 burners turned on it is over 400 degrees... any ideas?
Sounds like the regulator is not controlling the flow of gas. Try this. 1. Turn gas tank and burner control knobs off. 2. Turn tank valve on VERY slow. 3. Open front burner knob on and lite grill. Wait a minute and turn on addition burners, (if needed).
Apr 27, 2010 | Weber Genesis Silver A Grill
The electronic oven control my whirlpool GS470LEM is blank.
Check the breaker to see if it is tripped turn it off and back on,
Jun 01, 2009 | Whirlpool GS470LEM Gas Kitchen Range
Burner light stays on but burner does not work
Replace the burner switch, and you should be back in business. Hope this helps!
Feb 05, 2009 | GE JBP69 Electric Kitchen Range
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Display no longer works
Yes, I see this but it isn't real common.  The control board (eoc) will have to be replaced.  Most of them are costly.  If you give me the complete model # from the sticker on the oven (may be behind bottom drawer) I can check into this better for you and get you a price.
Oct 18, 2007 | GE Profile JS998 Kitchen Range
Oven does not heat
Gowen, more than likley it's your ignitor that failed. Remove the ovens bottom panel by removing the 2 screws in back and lifting up. Remove the nut from the flame spreader and you will see the ignitor. Now turn the oven on and look at the ignitor, does it glow. Even if it does, it needs to draw at least 3.2 amps to open the gas valve. Part number for the ignitor is 5303935066. Easy job. Catriver...post back.
Nov 05, 2006 | Frigidaire FGF316 Gas Kitchen Range
Thermador PRG364GLUS Gas Kitchen Range Logo
42 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
