Question about Singer 3343 Mechanical Sewing Machine
The foot controller wires came loose from the power cord connector of my 15-91. In what order do they reconnect?
    Problem Solver:
  • 9 Answers
If you're talking about the plug end, it should really matter. If there's a ground, that needs to be connected to the round pin that goes into the outlet, the two flat prongs don't really need to be assigned to a specific side.
Posted on Feb 21, 2009
Need the cord to my singer machine: model 2250/ serial # ZHC928602149 Where can I get one?
Several online shops have Singer sewing machine parts. The power cord is integrated with the foot control. Sewing Parts online has the part on the product parts page: https://www.sewingpartsonline.com/singer-2250-sewing-machine-parts.aspx . The direct link is https://www.sewingpartsonline.com/foot-control-and-cord-singer-359102-001.aspx . Singer also has the foot control and cord: https://www.singeronline.com/2250.html . Note: make sure to order the power cord appropriate for your location. These sites have the foot control for 120V (for North American outlets).
I hope this helps.
Oct 25, 2017 | Singer Sewing Machines
What would cause my Kenmore sewing machine's light to turn on but the motor seem to have no power?
The wiring for the older Kenmore is simple. The light switch completes the connection to the light. If the foot pedal has failed or connection loose where the wire attaches from the foot-pedal the motor will not run.
Also if the brushes in the motor are worn or failing to contact the motor internally the motor will not run.
With light on and pedal partially depressed attempt to activate motor to determine if brush connection are faulty. If the motor reacts at all the brushes will likely need to be replaced.
No success borrow a foot pedal from a friend or sewing center to determine if the pedal control is faulty.
Hope this helps?
Oct 15, 2016 | Kenmore Sewing Machines
My husqvarna meister model 2841 sews flatout
That control should be repairable. You could open it just to see if a wire has come loose and touching the other wire causing it to short. Dont loose the cord, you can use a generic controll but you need that cord.
Oct 20, 2014 | Sewing Machines
The cord to my footpedal only works in specific positions. Can I get just a new cord or do I need an entire new pedal?
you should be able to fix it yourself. Make sure the machine is unplugged from the wall socket. With the foot peddle upside down on a flat surfice, using a flat head screw driver, try prying open the foot peddle. Once open inspect the wires, one might be loose or disconnected and hardly touching the leads. Secure them if they are loose or reconnect them if unconnected. Close the foot peddle, plug in machine and try the foot peddle.
I hope this helps and saves you money on buying a new one.
Jan 20, 2014 | Sewing Machines
Designer 1 foot pedal won't work
Have you tried using another Designer 1 foot control? It is more likely that the problem is a loose connection at the machine. Do not cut anything apart on the foot control unless you are certain that is where the problem lies.Take the machine in to an authorized dealer and have them test it for you. Find out EXACTLY what is not working. No need to buy a foot control and find out that the connectors on the machine are not properly attached.
Dec 29, 2011 | Husqvarna Sewing Machines
My Pfaff 2030 model seems to have a problem with the connecting foot control. It cuts out and if I wiggle the cord and hold it just so it works. A bit hard to sew one handed. Can I order a new connecting...
You can order a new foot control complete or you can just order the cord for the foot control. If you just get the cord you will have to soldier a couple of things from your old cord to the new one.
Apr 26, 2011 | PfaFF Tiptronic 2030
Elna Lotus pressure foot contoller and power cord
You can use a continental converter this has the normal 3 pin plug with a two pin connector on the front - B&Q stock them
Oct 13, 2009 | Sewing Machines
Old model Bernina 830, running ok, then kept running, won't stop. disconnected cord, disconnected foot control, plugged cord into motor, motor runs without foot control. Reconnected foot control, motor...
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Jun 25, 2009 | Bernina Sewing Machines
My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
Mar 14, 2009 | Husqvarna Viking 1
Replacement parts
You can go into a full service fabric.repair service shop and they can order one for you. Ebay is also another great place to start. Its good to know what the plug looks like. Ebay currentlt has this power cord and presser foot for $34.99. Be carefull when ordering off Ebay look at the photos, many sellers are selling the presser foot without power cord and a live wire on the end where the cord should be, or the cord with a live wire where the presser should be, Make sure your getting the whole unit.
Jun 14, 2008 | White Sewing 1632 Mechanical Sewing...
Singer 3343 Mechanical Sewing Machine Logo
99 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
