Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
My mower only runs full throttle.
Rover sprint 375 easystart 98902(briggs & stratton engine)
my crazy mower will only run full throttle,i have cleaned the air filter and replaced the gasket under the air cleaner also have replaced throttle and torque springs connected to carby with no results.
  • 1 more comment
  • cyclingo Mar 07, 2009
    Think my governor spring is stretched and isn't working properly. I have full throttle, and that 's it. tends to cut out when mowing as well.
  • Anonymous Mar 14, 2014
    Spring set up
  • Anonymous Mar 26, 2014
    new spark plug new air filter and cleaned carby and still running rough 4 stroke 158cc Briggs and Stratton motor
    Sergeant:
    Champion:
  • 320 Answers
The internal govner is a good option.
Posted on Oct 18, 2013
I have no solution, I have the same problem, engine runs full speed WITH THROTTLE PLATE CLOSED. I took the carb off and cleaned it, when I put it back on it ran full throttle with butterfly closed. I figured I had lost something so I ordered a completely new briggs carb and sure enough it runs wide open WITH THE BUTTERFLY COMPLETELY CLOSED. I know that it seems impossible, but is true. I need help.
Posted on Oct 26, 2011
  • Clyde Roberts Oct 26, 2011
    The post I did above about full speed with closed throttle plate is on a briggs&stratton 14.5 HP engine.
Briggs and Stratton motor mower. Model "Sprint 375" two stroke.
pull the carby and clean it out
clean out the main jet and the blockage in the needle and seat area
check that the tank cap vent is clear
May 06, 2016 | Garden
Why don't I get spark on my briggs and stratton 3.75 model 98902
Did you check the ignition shutoff wire? Make sure it isn't grounding. It is a common Briggs problem. Take the wire off of the switch contact and check for spark again.
Aug 19, 2014 | Garden
Why does engine run at full trottle only?
Mark it sounds like there may be a problem with the air filter. If its revving and running to fast all the time clean the air filter.
Aug 01, 2014 | Briggs AND Stratton Intek Briggs &...
Briggs and stratton 3.75 sprint engine handle throttle doesn't change speed
there is a long spring that goes from the level the cable connects to to the governor rod does that have any tension on it?
Apr 26, 2012 | Garden
I have a Victor 4-stroke (sprint 375) which is 8 yrs old. Never missed a beat until yesterday where the engine now revs, then almost cuts out, then revs, then almost cuts out etc. All 'obvious' components...
You need to take the carb off and clean it out real good.i would suggest taking a bread wire and run through the passages in carb then soak in mineral spirits or other cleaning solution.blow out with air hose.
Dec 10, 2010 | Briggs & Stratton Garden
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
The engine on my Sprint 375 floods when trying to start
Check the float in the carb. bowl for gumming and clean your carb.. If you haven't done so already. Or you can try running a fuel treatment through your fuel. That may help you with your flooding issues. Good luck.
May 04, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mower stutters when i turn up to full throttle.
Hi if it is older than 2 years it will need a new diaphram and gasket under carby you will also need to clean out the fuel bowl in the top of the tank this should fix your problem.
Apr 03, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
you need to clean the breather out it is located on the side of the valves it is a rectangle shape and has a hose coming out of it to the air filter have you took the carburator out and cleaned the jets as well?
Apr 02, 2009 | Garden
Poor running engine on my lawn mower
I think you need more than a screw adjustment in the carburetor. It sounds as if you need a full tuneup. This means air filter, gas filter , carb. rebuild ,spark plug etc. Good luck. donnyb60
Mar 22, 2009 | Briggs & Stratton Garden
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
3,172 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
