Question about LG Dare VX9700 Cell Phone
My screen is turning blue!?!?
My LG dare has water damage but everything seems to be working fine. BUT the damage is making everything on my phone an aqua blue color. the background on my phone is a black and white picture but the damage has made it black and blue. sometimes it shuts down but i can still call and text people.what do i do to fix the problem?
  • Anonymous May 25, 2009
    I have this problem to. But mine randomly goes back to the normal color. It pisses me off
Don't let it sit for thirty days. It will corrode the metal contacts and then deposit the dissolved metals when it evaporates.
Instead, try this easy and cheap fix. Order some DRIERITE or beg a friend with access to a chemistry lab to get you some. It's a reusable desiccant used for pulling water out of mixtures. Heat up about a pound of it in a shallow pan until it's dry- the color indicating type will turn blue. Pour it into a Tupperware, the shallower the better. (More surface area.) Lay a bit of paper down atop it once the dust settles, while it's still quite warm. Then lay your phone atop the paper with the battery separate from the main phone. Seal the Tupperware.
Whenever the DRIERITE is near saturation (for the color indicating kind, it will turn pinkish grey) shuffle fresh grains from the bottom of the Tupperware to the top. Removing the phone and heating the DRIERITE in the original shallow pan and repeating all the steps helps, too. As it cools, it pulls moisture from the air inside the sealed Tupperware.
My LG Dare fell into a toilet and jammed in the pipe, took five solid minutes underwater to free it. The DRIERITE cleared it out in less than three days.
Posted on Mar 02, 2009
  • 6,784 Answers
Unfortunately, this problem will get worse. Good rule of thumb is to take the cell battery out of the cell phone immediately after you remove it from the moisture. The phone should dry for 30 days before inserting the battery again. re inserting the battery to soon will cause major damage over time. what you are experiencing is LCD bleedover due to the water damage.
Posted on Feb 20, 2009
Is my phone done?
if the rice trick does not work, you can also try blow drying it on low heat, but at this point, sadly, it probably is
Jun 05, 2013 | LG Dare VX9700 Cell Phone
How do i turn on my lg dare vx9700 cell phone after charging phone?
hold down the red button until it turns on....if you bought it used check for the dot on the inside of the phone under the battery to show a red or dark color mark....this means it has water damage and the phone could be junk
May 05, 2011 | LG Dare VX9700 Cell Phone
I replace my crack lg dare lcd screen but when i turned it on here is no picture
Hi, it sounds that the screen you replaced is either not placed to well or the screen is not too good.(damaged).
You can unscrew the phone and try to adjust it, and see if it will display,if it does not display,that means the screen is damaged.
Take care.
Aug 07, 2010 | LG Dare VX9700 Cell Phone
My LG Dare froze and is on the Verizon screen. It
try removing the battery (check for signs of water damage) and leaving it out for a while
if you put the battery back in, and there were no signs of water damage, and this continues, the best thing to do is to take it to a store because if it is under warranty they will replace it
please remember to download backup assistance to save your contacts going forward
Nov 11, 2009 | LG Dare VX9700 Cell Phone
My lg dare has a cracked screen inside
yes you can all you have to do is buy a new LCD an replace it but if you dont know how to open it just bring your phone to LG service centers
Oct 30, 2009 | LG Dare VX9700 Cell Phone
LG Dare water damage
how long has your phone been in rice? 2 days? that is how long it is supposed to be in rice. you could try recharging the battery for how ever long it takes for it to load. but those phones are pretty delicate so unfortunately there is a good chance its gone.
Jun 27, 2009 | LG Dare VX9700 Cell Phone
LG Dare dropped in Pool
Just put it in a bag of rice for couple of weeks. The rice pulls all the water or wetness out of the phone. How do I know, Well I found a brand New Lg Dare phone in a puddle, put it in rice for 2 1/2 months. I took it out of the bag, put it together, turn it on. To my amazement it worked. Ran to store, bought a charger, and it has worked every day since.
Jun 18, 2009 | LG Dare VX9700 Cell Phone
Broken screen on lg dare Broken touch screen. can it be replaced? got my phone wet for a second. dried it off. everything works, but my touch screen will not respond on the left side of the phone. water...
ive had a similar problem... but what i did is i looked at what the insurance does cover... since it doesnt cover water damage.. defect the phone in some way that the insurance will cover. its only if you're in desperate need. there is no way to fix water damage... but i know PLENTY of tricks to soak water out of the phone
May 30, 2009 | LG Dare VX9700 Cell Phone
You can buy a new water proof touch screen online and you will be able to go to a Verison store and have them install it for you. Also put the phone in a zip-lock bag full of uncooked rice for several weeks. Make sure the battery and phone are in the bag seperately.
Jan 02, 2009 | LG Dare VX9700 Cell Phone
LG Dare & LG ENV2 BOTH DEAD
i was talking on my phone yesterday and i just shut off. i plugged it in and it has a full battery but every time i turn it on it only gets to the "registering apps" it shuts off. what is wrong with my phone?
Sep 03, 2008 | Cell Phones
LG Dare VX9700  Cell Phone Logo
829 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
