Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher continues to run beyond necessary time
When I run my SHE43C on the normal wash cycle, it sets a time for 2 hours and once it gets to 1 minute, it will continue to run unless I stop it and then I have to drain. I do not feel it is sanitary.
  • 70 Answers
Most likely the microprocessor has failed
Good Luck!
Posted on Feb 21, 2009
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
The dishwasher runs for 1 1/2 hours on the wash cycle.
This may sound strange but that is a normal cycle time for today's dishwashers. They use much less water and the water is 'recycled' within the filtration system in the pump.
By reusing and filtering this water they save on heating energy and water consumption. The motors are not as powerful so they use less power even when running longer. Many machines will alternate the wash between the upper and lower arms, this type uses much less water and energy but again the trade off is long cycle times.
If you were to select a heavy or pots and pan cycle with hi temperature wash and a sani rinse your times can be up to 4 hours in some machines today.
The reason behind these savings are mostly due to the energy standards that the appliance manufactures have to abide by today.
I know this may not have been what you wanted to hear but it is how they work today.
May 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
My dishwasher takes 2 1/2 hours to run. Is this normal?
Smart wash: 2 hours Anti-bacterial wash: 2.5 hours Normal wash: 2 hours China/Gentle: 1.5 hours Quick Rinse: 10 minutes
Note: If water temperature is low the times shown above will be extended to allow for water heating time.
This information is from page 14 of the manual.
Jan 16, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
I have just moved into a resale home{two years old} and the bosch dishwasher has a terrible odor what do i do?
Works for me, empty the dishwasher of any dishes, silverware, pot or pans, get (2) jars of "Tang" orange drink. Use (1) jar to fill the soap dispenser and poor the rest into the bottom of the dishwasher.
Run the dishwasher through a normal wash cycle with no heat/dryer time.
Run a second time if necessary. The orange juice acid will dissolve the build up in the dishwasher and rinse it away. It also smells good when your done.
For regular maintenance, repeat once every 3 months or so. It will not harm the dishwasher and will keep the interior components fresh and clean.
Good luck.
Oct 23, 2009 | Bosch Dishwashers
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Maytag dishwasher
Hi kimleh.
I'm Harvey the Master Plumber.
Your question is: The dishwasher goes through the first wash cycle on a light setting and first two on a normal cycle but will not continue.The motor hums but does nothing else.It drains fine as well after the wash cycle.
Without additional info it sounds like a control problem. Must be a warranty call. If beyond warranty then you have to decide whether it's more cost effective to repare or replace it.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 12, 2008 | Maytag Dishwashers
Bosch dishwasher cycle doesn't end
Try this link, http://www.applianceaid.com/boschDW.html for procedures for running self-tests on various Bosch models using the front door switches. Find your model and read and follow the procedure.
This remaining at '1' problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. See pic here of open solder joint http://www.flickr.com/photos/zenzoidman/145089572/ In most cases, the heating element has not been at fault.
I got mine going again by resoldering the joint and saved ~$300 in parts & labour. If this is beyond your skill set, then replace the control board assembly, 266746, which is used on multiple Bosch models. See this page for more information if you want to try to DIY. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
If this is still beyond your skill set, then call a tech & supply the Bosch model, serial number, and the results of the self-tests.
Jul 08, 2008 | Dishwashers
Asko 1585 wash cycle goes continuously until manually shut off
it may be a heating problem,does it get hot at all, or over heat.may be a thermistor fault.remove the door skin and see if rinse aid has leaked onto the wiring.or the board itself cauld be faulty,but are very expensive.hope this helps.
Mar 22, 2008 | Asko 24 in. 1585 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
239 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
