Question about Pyramid 1000W 2CH SUPER BLUE AMP Car Audio Amplifier
Pyramid PB449X In Protect Mode
I have a Pyramid PB449X 2ch. amp. I bought not working cause thats what I do, buy them broke, repair & resale. I'm an electronics tech with 2 degrees and 15 yaers experience. Just to let who ever helps me out knows my background in the eclectronics field. Anyway back to the amp. Put power to it protect light turns on immediately. I checked all the transistors and mosfets on the power supply section, everything checks out fine. I thought a main diode coming from the power hook up point was bad but replaced it and still nothing. I even checked out the small transistors and all the zener diodes and all check out. I might have miss read something when testing. So I guess I'm gonna see where the powr stop at. Trace the power till I find a spot where there is suppose to be voltage. Maybe that will lead me to it. Well, if any one can give me some suggesions I would appriciate it. I just can't think anymore of what to test. Help get amp going please.
    Novelist:
  • 90 Answers
The protect light is a notification that the amplifier has reached a set temperature and shuts the amp down till it cools off. Look for the thermosister on the heatsink and follow the circuitry back to the control chip. Once you get that fixed the amp should power up until it gets too hot and the protect circuit kicks in. I had one of these amps for a while and the circuit was very touchy. Regards, rcampsr
Posted on Feb 21, 2009
I have a Crunch Powerzone Pzi2250 1000 Watt Amplifier. and the red light blinks. What does that mean
My crunch powerzone pzi2250 1000 watt 2ch amp is stuck in protect mode. How do I fix this at home
Jan 16, 2011 | Crunch Powerzone P4175 Car Audio Amplifier
Bought a car and this amp was in it(Pyramid Crystal PB781X 2ch MOSFET). it is missing the fuse. what fuse does it require?
25 to 30 amp fuses are the most commonly used fuses in any amp and since yours is a 1000w amp, I would use the 30a.
Sep 05, 2010 | Pyramid 2CH 1000W CRYSTAL AMP Car Audio...
I have a pyramid amplifier for my car and i
Professional repair is required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 28, 2009 | Pyramid PB1281X Car Audio Amplifier
Pyramid arctic 4ch amp pb1617x goes right to protect mode when turned on wires are good fuses are good to. how do i fix it
pull out 1 rca jack at a time and try it..usually speaker wires touching...or blown speaker
Nov 08, 2009 | Pyramid PB1617X Car Amp
Green and red light are on my pyramid amp and its not working
It could be even simpler than that, yes an improper impedance rating on an amp will cause it to overheat, but should function temporarily until it reaches peak temp. If the outputs were blown the protect light should not light up being that they would need to work to cause the protect light to come on. I would double check all of your connections, one small little crossed wire would cause an amp to immediately go into a protect mode.
May 29, 2009 | Pyramid PB1217X Car Audio Amplifier
Wont work
I have the same amp I just bought off e-bay not working. It's what I do. I buy amps that don't work then repair them and resale. Anyway mine did the same thing and your problem is shorted output transistors. Find which ones and replace. But, since this is a 1 channel amp you will want to replace all the output transistors. Make sure the replacements are from same manufactuer, same date code/ batch number. It's better to have transistors that are from the same batch cause mixed transistors can have little variations that might cause problems later on. Good luck and let me know. I will help you if you need more help.
Feb 04, 2009 | Bazooka EL1500 Car Audio Amplifier
Amp power
open it up and check the board and magnets on the side if it smells funny and looks like black resin its burned out
Mar 25, 2008 | Pyramid 2CH 1000W CRYSTAL AMP Car Audio...
Pyramid 1000W 2CH SUPER BLUE AMP Car Audio Amplifier Logo
364 people viewed this question
Top Pyramid Car Audio & Video Experts
Greg Cann
Greg Cann
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
