Question about Maxtor Hard Drive
Jumper settings wd1600
Jumper settings on wd1600 master setting and adding second drive as slave jummper settings should it be master w/slave present just checking
  • 6,784 Answers
Yes, you are correct.
Posted on Feb 20, 2009
I replaced the dvd drive with a gdr8162b and added a sony cd/rw Crx217e-ds this computer is a dell 4600 cant get neither of the drives to work
If these drives are IDE deives then check the jumper settings on these drives.
The jumper setting for master (MA) and Slave (SL)
If one of these drives is on the same data cable as the hard drive the the jumper setting for this drive MUST be set to Slave (SL) because the hard drive will be jumpered as Master (MA).
If both of the drives are on the same data cable and the data cable is plugged into the second IDE controller then one of the drives MUST be jumpered as Master drive and the other as Slave drive.
Jun 01, 2012 | Dell Dimension 4600 PC Desktop
I wish to us a WD1600 (caviar) hard drive fopr extra storage in my pc the drive came from my old PC there are eight pins to choose from. Where do I place the jumper?
Well, if this hard drive is SATA and looks like this:
Then you don't need to worry about the jumpers at all, the hard drive is ready for use in your PC.
However, if it's IDE, which looks like this:
You will need to move the pins to the "Slave" setting, and on Western Digital drives it is one set of vertical pins going away from the 4 pin power input, the above picture is set for Slave mode, and can be used as a reference.
May 05, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
Want to install wd1200jb-75cra0 as slave drive in dell xps420 with vista operating system operating master drive. do i need a driver installed first before it will recognize the wd1200 as a slave?.
there is a jumper setting on the drive itself that determines master and slave. Look closely at it, there is always a diagram of the pins to connect or disconnect for master slave setup.
No longer needed with Sata drives...
Feb 18, 2011 | Western Digital Cavier SE WD1200JB 120 GB...
Hi i have a western digital wd1600 160gb hard drive last year i used the hirens boot disc to completely wipe my hard drive and repartition the drive but now when i try to use my western digital tools for...
Have you tried setting the jumpers on the new drive to CS (cable select) If you use that setting, the position of the drive on the cable determines whether it is master or slave. For example, the plug at theend of the IDE cable is the master and the plug in the middle of the cable would be slave. Just a suggestion. If you are using SATA, this does not apply.
Jul 18, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
How to install hitachi cdr-7930 on my dell dimension 4100 window xp home edition it doesent computer fails to boot with it hooked up
If this is a IDE drive...You may have the data cable connected the wrong way around. Do you only have one hard drive installed..? If you have and you are connecting this drive on the same data cable as your hard drive, you need to set the hard drive to "slave present" or "Master" and the dvd drive to "slave" If this is a SATA drive, you do not need to do this and you may have a faulty drive.. On the rear panel of the drives (where the cables plug in) is a jumper pin. Now either marked on the case or even on the drive label are the meaning of these pins. There are usually four sets of two pins laid out vertically. You need to put the little black jumper onto the pins marked "slave" on the dvd drive and "slave present" or "Master" on the hard drive if they are both on the same data cable. you can also set both drives to "cable select" but you then have to use the correct connector on the data cable for each drive. try the slave and master settings first, if you have no luck, message me again..
Dec 30, 2009 | Hitachi (CDR7930) Internal 8x CD-ROM Drive
Can I use a WD1600 as slave drive and Maxtor 6Y200P0 as master? If I can what are setting on Wd1600.
You just need to put a jumper on the pins on the side of the hard drive that is marked on the label to SLAVE, then connect it to the ribbon and power.
See document below for extra help:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ata_jumper_settings&vgnextoid=cbc974850ce0e010VgnVCM100000dd04090aRCRD
Apr 20, 2009 | Computers & Internet
Slave jumper setting
SATA drives don't have jumper settings.
You can set master/slave in BIOS.
Mar 29, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
I NEED HELP HOOKING UP MY WESTERN DIGIAL WD5000G032
If this drive is only for storage it can be set as a slave drive. If it will have the OS installed and will be the boot drive it has to be set as master. Set the jumpers accordingly. If a different drive is the master you might check the jumpers on that also. I have seen some drives with a (master/slave present) jumper that might need to be changed as well. Most WD drives have a jumper settings diagram on the case.
Dec 16, 2008 | Computers & Internet
Power up problems
To enter setup (Refering to the bios/cmos), press the Delete key very two seconds untill the bios main menu loads. You need to go to the menu heading - Boot.
If you added another hard drive to you're system the IDE (hard drive) it's jumper settings may not be correctly set. If there are now two IDE drives both the primary master & secondary drive's jumpers must be set correctly. You will ned to look at the white sticker on the drive for the correct jumper settings. Many primary IDE drives pin jumper is set as a single master drive with out a secondayr drive attached in the system. When you add a second drive the pin jumper one the master drive will most likely need to be changed to master with a slave. The second drive will also need it's jumper set as a slave drive. Once this has been adjusted you need to enter the bios & make sure you're primary master drive is set in the boot order. Most PC's boot order is as follows.
1st Boot device, floppy drive. (If one is connected to the system).
2nd boot device, CD-ROM drive.
3rd boot device, master IDE drive.
Please use the help of you're manual to guide you for these settings.
AOpen MX46L web site. http://download.aopen.com.tw/Default.aspx
You must set the three drop down menu's to get you're board's drivers & manual. In the first menu choose motherboard, in the second menu choose MX46L & in the last menu choose manual. For drivers, the third menu choose drivers.
Still heave more questions? Just ask.
Mike
May 18, 2008 | AOpen MX46L Motherboard
Maxtor Hard Drive Logo
1,553 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
