Boston pencil sharpener part
I need a drive gear for my Boston model 17 pencil sharpener. Where can I get a replacement part?
RAR
Try here:
http://www.spodaco.com/xactoland.html
Posted on Feb 21, 2009
Tip
How to sharpen a pencil so the tip doesn't break
When I was in school it would always frustrate me that the tips of the pencil were always breaking in the sharpener. It took many tries of turning the pencil and turning the sharpener, different amounts of pressure and I finally found the secret.
Sharpening a pencil is a very easy thing to do. When you are using a hand sharpener, either a small plastic one with a cartridge to catch the shavings or the really small ones that don't catch the shaving, your put the utencile end of the pencil into the sharpener keeping it has straight as possible.
Applying a little pressure turn the pencil in the clockwise motion (you can turn either the pencil or the sharpener both will work). The shavings will begin to fall off and you keep turning until either you are satisfied with the sharpness of the tip or the shavings stop coming off. Make sure that you don't put more pressure on the pencil to make the shaving keep coming off because that will make the tip break and get stuck in the sharpener.
Pull the pencil out and clean the sharpener, it should be good to go. What I discovered was that if I had dropped a pencil a few times then the lead inside the pencil would be broken and this would cause the tip to break after sharpening. Treating your pencils nicely will keep them from breaking tips when you sharpen.
on Jan 30, 2014 | Office Equipment & Supplies
Misplaced my power supply for my 1950x pencil sharpener and can`t find the output or polarity labeled on the thing?
I have the same sharpener. Input is 120v AC 60Hz 16W which is what comes out of the wall in USA.
Output is 12V 800mA and the polarity is positive in the inside of the plug. I'll try to attach a photo to this post.
misplaced-power-supply-1950x-pencil#solution-section-kjptrdwcwv032w1lziamb525-3-0.jpg
Mar 02, 2014 | Boston Acoustics Mighty Mite Electric...
Crayon is stuck inside pencil sharpener
Hello, I need the model number of the pencil sharpner. You might go to bostitch and call support for help.
Jan 10, 2014 | Stanley Bostitch Electric Pencil Sharpener
What kinds of pencil sharpners are there?
There are many kinds of pencil sharpeners that have been developed through the years.
The most common ones, the manual sharpners, can be of the following kinds:
Mechanical sharpeners: a portable variety, usually small and in the shape of a rectangular prism. The blade inside rotates around the pencil, sharpening it. The shavings emerge through a slot.
Blade sharpeners: small and portable, hold replaceable shaving razor blades or permanently fitted blades. They work similarly to knives, but in a more convenient and safe way.
Cylindrical cutters: larger variety, stationary, powered by a crank. One hand holds the pencil, the other turns the crank.
Another common pencil sharpener found often in offices is the electric sharpener. It works on the same principle as the manual sharpener, but the blade rotates quickly thanks to an electric motor, either powered by batteries or plugged into the electrical system.
There are still people, mainly artists, that sharpen their pencils with a knife.
Oct 06, 2013 | Office Equipment & Supplies
What is a pencil sharpener?
A pencil sharpener is "a device for sharpening a pencil's writing point by shaving away its worn surface. Pencil sharpeners may be operated manually or by an electric motor." (wikipedia)
Help with my Royal p70 electric pencil sharpener and I can't seem to get anywhere... A lead is broken in the sharpening gears and I don't know how to take apart the sharpener to remove it.. Ca
Turn sharpener upside down. On the bottom, you will see 6 black dots. Four of them are Legs while the middle two are covers to two screws. Peel the stickey cover off the middle two, exposing two phillips head screws. Once the two very long screws are out, the entire unit will fall out of the casing. You may have to push in the small plastic locking devise at the bottom. Good Luck!
Jan 27, 2013 | Royal Pencilsharpener P70
Is there a pencil sharpener that I can sharpen several pencils at once?
I don't think there is, but there's a sharpener with different size holes for different types of pencils: http://www.officedepot.com/a/products/744792/Stanley-Bostitch-Classroom-Electric-Pencil-Sharpener/?cm_cat=2000000361
Jan 24, 2013 | Office Equipment & Supplies
Ieed a drive gear for hunt model 17 pencil sharpener
There is a seller on e-bay who manufactures the gears for the models 17, 18 and 19 in small quantities. He just posted more of them on e-bay as of 1/11/13 and his seller name is valens61. The cost is $12.50 with free shipping.
Dec 05, 2012 | Office Equipment & Supplies
598 people viewed this question
k24674
jasbo
jasbo
