Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How do I remove a Konica Minolta Bizhub 352 transfer belt?
I can't lift and remove the transfer belt on the tight side. The left side is lifted and ready to pull out, but the right side will not lift up? Am I missing a release? Do I need to remove the side bracket screws? Thank you for your help in advance.
  • 24 Answers
Two screws front and rear need to be removed before the belt will come out, it is light sensitive so keep it in the dark.
Posted on Jun 25, 2009
    New Friend:
  • 51 Answers
Yes and move the metal bracket to relis the belt
Posted on Sep 17, 2009
Please how do reset transfer unit unit on konica Minolta bizhub c-252
for reset belt unit you have to change one fuse.
You need a new 50-80 ma fuse.
Remove the belt from the machine, the fuse is in the left side of the belt, under the left handle.
Replace it with a good same fuse.
For detailed guide see the link below:
Konica Minolta Service Manual
Aug 06, 2016 | Konica Minolta bizhub Office Equipment &...
How can i fix konica minolta bizhub c6500 error code c-2804
WHAT EVER YOU DO DO NOT PLACE ANY PRESSURE ON THE FOUR LARGE SHAFTS THE TURN THE DRUMS
Pull out the Drum and Transfer belt section. then from the right side gently clean the three sensors that site across from the belt. all three have metal covers BE CAREFUL they also have tiny springs don't lose them. Just lift them and clean the sensors with a dry rag. AGAIN do not touch those large shafts. if the cleaning them does not work remove the assy. two screws one connector. Don't lose the screws. Also clean out the Transfer belts cleaning blade unit remove hard toner remove the assy. and disassamble. Then run the gamma procedure in 36 mode.
Aug 19, 2015 | Konica Minolta Office Equipment & Supplies
How do I remove the transfer belt from c450 bizhub konica minolta
1st from the front Open the door and removed all Imaging unit start from the black. 2nd from the left side when your facesing the c450 Open remove the waste box. 3rd from there you will see the transfer belt on both side of it you will see screw just under the transfer belt loose it. Slide the transfer belt toward you.
Jan 08, 2015 | Konica Minolta bizhub C450P Laser Printer
Where is the transfer belt located on a Konica Minolta C25
above the 4 drum units have to remove the 4 toners the 4 image units and the transfer belts is removed from the right side after removing a section of the duplexer on the right side door.
May 08, 2014 | Konica Minolta Bizhub C25 C35 C35p Color...
C0208 error
Tray four lift ! REMOVE THE EXTRA PAPER FROM TRAY ON THE LEFT SIDE not a storage area!!!! Then check behind the the draw remove the paper, worse case you have a burned out lift motor or board or both.
Jan 28, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Image Transfer Belt Installation for Konica Minolta Bizhub C351
Transfer belt on this model is removed via left and right side of the machine two screws on the right side remove then the belt is pulled from the left side
Jun 23, 2010 | Minolta C350 Printer
Replacing a transfer belt on a Konica BizHub C500. How do you replace it? Or which side of the transferbelt unit do you remove?
if i remember right, open right door, remove 2 tbu lock scews, open left cover, remove waste box and then remove tbu
Dec 10, 2009 | Konica Minolta bizhub C250 All-In-One...
Where can I get instructions on how to replace the transfer unit of my Bizhub C252?
Please visit the site http://www.resetkit.eu
There you can find how to reset your fusing unit and transfer kit unit for almost all Konica Minolta MFP's and printers, Bizhub C252 included.
You don't need to replace it, you can just reset it and save a lot of money.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Oct 22, 2009 | Konica Minolta bizhub C250 All-In-One...
How do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
318 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
