I am searching for the radio card driver, the type is Mediaforte and the serial number on the card is AU036278 other specifications shown on the same radio card is (OC PASSEID) A0024 i will be grateful to you if you support me with the appropriate driver for this card, specially it did not came with XP , only for windows 98,95 and NT thanks borz31@yahoo.com
  • 4,338 Answers
Try this site: http://www.mediaforte.info/support.htm If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 20, 2009
Is the serial number J96107 a real serial number? I was told that they only went up to J96096.
As with any hardware, you need to supply a "brand name" or manufacturer and what the "model number" is. Of course, a model number is not a serial number. Even within a brand, each model may have its own set of serial numbers. I suggest you do a google search for "brand serial numbers" replacing the word brand with your specific brand. But here is a short cut that may serve you well:
http://musictrader.com/?page_id=61
If you want to try another type of direct google search for your:
If you do not know the brand, then try the type of instrument and serial numbers. That may offer you a list of different instrument brands with links to serial numbers associated with them. Here is a result for a search for clarinet serial numbers.
For example: http://www.woodwind.org/clarinet/Equipment/HowOld/
Aug 26, 2015 | Music
Need a radio code for Ford Fiesta 2005 with serial M566060
Need to get code from Ford dealer! take Owners card and serial number with you.
Dec 24, 2014 | Ford Cars & Trucks
Radio code retrieval 2002
ive now posted this now , 10times. the op guide covers this , open glove box............................. searches work so does google.
here is 11.
2008 opr.guide.(lost it, huh?) Accord. non satellite
Quotes: (glove box. guide, quotes)
Your vehicle's audio system may disable itself if it is disconnected from electrical power for any reason. { no, will , it will}
To make it work again, you must enter a specific five-digit code with the preset buttons.
Because there are hundreds of number combinations possible from the five digits, making the system work without knowing the exact code is nearly impossible.
You should have received a radio code card that lists your audio system's code and serial numbers. {glove box find}
It is best to store this card in a safe place at home. In addition, you should write the audio system's serial number in this owner's manual.
{id not do the latter}
If you lose the card, you must obtain the code number from your dealer.
To do this, you will need the audio system's serial number.
If your vehicle's battery is disconnected or goes dead, or the radio
fuse is removed, the audio system will disable itself. If this happens,
you will see ''ENTER CODE'' in the frequency display (on the screen on models with navigation system) the next time you turn on the system.
Use the preset buttons to enter the five-digit code. The code is on the radio code card included in your owner's manual kit.
When it is entered correctly, the radio will start playing.
If you make a mistake entering the code, do not start over; complete the
five-digit sequence, then enter the correct code. You have 10 tries to enter the correct code.
If you are unsuccessful in 10 attempts, you
must then leave the system on for 1 hour before trying again.
The system will retain your AM and FM presets even if power is disconnected. {only on newer cars}
General information on Honda and DIY:
{the code can be obtained from any Honda dealership (you must give him/her your radio serial number (sticker off radio)"}
or any locksmith with a license from..NASTIF
Honda1 ServiceExpress (Same info as ISIS)
Acura ISIS (Dealer version w/ advanced search)
http://nastf.org/i4a/pages/index.cfm?pageid=3462
no more need to ask, right?
Dec 04, 2013 | 2005 Honda Accord
How do I get the radio to work after disconnecting the battery. The owners manual was stolen
input the security code, if you losen your card, remove the audio panel and then pull out the radio and tape player partially, read the serial number shown on the name card of radio and tape player,look-up the anti-theft code corresponding to the serial number code table, or make inquire to mitsubishi service center
Jun 19, 2010 | 1996 Mitsubishi 3000GT
Battery died on my 2000 honda accord- need code
Sorry, there are virtually an infinite number of possible codes.
If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code (some people say that they have found the code on a sticker inside the glove compartment, but I wouldn’t count on that). Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner’s manual for the specific procedure (the following usually will work: Turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release.)
. Some older vehicles (model year 2003 and older) require a visit to the dealer in order to retrieve the audio unit serial number. Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
I'm sorry I can't be more helpful than to let you know how to begin the process.
Nov 18, 2009 | 2000 Honda Accord
How can i encode the radio serial number to the sterio of my honda civic 2001?
If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code. Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner’s manual for the specific procedure (the following usually will work: Turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release.)
hope this gets you started on the process.
Nov 15, 2009 | 2001 Honda Civic
I need to unlock a honda accord 1995 radio
FREE and EASY methods to get your Honda radio UNLOCK CODE. (Dealerships usually charge)
Assuming you don't have the Anti-Theft Code and Serial Number that is found on the credit card sized Anti-Theft Radio Identification Card that comes with the vehicle at the time of purchase and is usually found in the glove compartment....
You have
FREE options to retrieve that code by phone or on the internet BUT, the RADIO SERIAL NUMBER is REQUIRED (no matter what). (see bottom about removing ERROR E3)
***IF your Honda was made BEFORE 2001 the serial number
MAY not be accessible without removing the radio from the vehicle.***
* TO
GET THE SERIAL NUMBER (so that you can get the unlock code)
1. Get something to write with and on (you'll need it to write down the serial number)
2. Put the ignition key in and turn it until your able to turn your radio on (accessories position).
3. Then turn your radio OFF by it's knob/button (but leave the ignition key in place).
4. Hold down the preset buttons 1 and 6 at the same time.
5. Turn the radio on while pressing down both the 1 and 6buttons.(***IF your Honda doesn't have preset buttons on the radio then hold down the top part of the 'Seek/Skip' button
AND the top part of the 'Change Disk' button instead.*** )
6. Write down the 4 numbers you see first and then 4 more that display. These eight numbers are the SERIAL NUMBER. This is NOT your CODE.
7. Make sure your VIN (Vehicle Identification Number) is handy to get the unlock code. (can be found on your insurance card, driver's side door jam, small plate on dashboard by registration and inspection stickers, etc)
* TO
GET THE UNLOCK CODE (using the radio Serial Number and VIN)
---Internet option:
1. Go to https://radio-navicode.honda.com/ (YES, it's run BY HONDA and IT'S
FREE)
2. Follow on screen instructions (Serial Number and VIN required)
3. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
OR-
---Telephone option:
1. Call American Honda Customer Relations (800) 999-1009
2. When the automated message starts 'Press 3' for 'Radio and Navigation Codes'.
3. Tell the Customer Service Agent you need your radio code. (They will ask for your name, your radio's serial number, VIN, etc)
4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT
SAFE!
5. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
* REMOVING ERROR E3
****If you entered too many wrong codes and got an ERROR E3 message displaying you'll need to do an additional step for even the correct unlock code to work.****
Disconnect your negative battery terminal (or pull the radio fuse out if that's easier for you) for 30 seconds then reconnect it and then the radio will say "CODE" again and you can put in your correct unlock code.
Oct 10, 2009 | 1995 Honda Accord
Code is there with serial number but the radio does not accept
Make sure the numbers match. The serial number is etched into the housing of the radio-starts with S/N ###etc. If you are unsure, write down the complete S/N off the radio housing and call a dealer-they will not charge to look up a radio code-it only takes a minute. If they give you a different number, then your head unit has been replaced at some point and your current card is no good. If they give you the same number, then try one more time and press seek when done. If it still does not accept it, then there may be an internal radio problem.
Nov 14, 2008 | 1998 Mercedes-Benz C-Class
SUNHILL
If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code. Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner’s manual for the specific procedure. Some older vehicles (model year 2003 and older) require a visit to the dealer in order to retrieve the audio unit serial number. Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
Aug 07, 2008 | 2004 Honda Civic
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
