Question about Grilling
Gas grill ignitor no longer ignites burners
I have a Char Broil model 463241004. The ignitor no longer ignites even after replacing the battery. I do not hear the 'click, click' of the individual ignitors when holding in the ignitor button.
Is there a way to determine which of the items in the ignitor system is bad? The main switch is a RichTek ZT-XJ4-4 (this is the original unit used in the grill for the Char Broil part number 80000690).. Can this item be easily tested?
  • Anonymous Apr 15, 2009
    how do you remove the ignition?
  • Anonymous May 05, 2009
    I cannot get my Char Broil Performance Series Grill to ignitie. Someone said the igniter is operated by battery but I cannot find a battery to replace. Also, on the two occasions I lit the grill manually (with matches) it did not heat sufficiently to cook at all. Can someone help me?
    Harold Sullivan
    harbren2@yahoo.com
  • 398 Answers
It is bad you need a new igniter, the flint part goes bad
Posted on Feb 27, 2009
I had to change the burner but now the igniter will not automatically ignite when pressing the button. What should I do?
The piezo ignitor head my need to be adjusted so that it is closer to the burner. If it is not sparking at all, check for a loose wire at the piezo ignitor and trace it back to the ignition button. Often times, it will simply lost it's ground. To resolve this, carefully pull the ignitor wire off the piezo pin and the push it back on. Do the same thing on the back of ignitor button.
If none of the above solves the problem, it's time to replace the ignition systems. The parts are inexpensive and can be purchased on-line directly from Char-Broil http://www.charbroil.com/Store/ReplacementParts.aspx or from any home center or hardware store that sells gas grills and accessories. These will be universal fit model ignitors .
Hope this helped you. Please let me know. Thanks.
May 31, 2011 | Char-Broil CharBroil 4637318 Grill
Need a new ignition swicth. year 2005 model DHLB
Whether it's electronic ignition or the old, standard, push button piezo ignitor, you can find it at the Char-Broil Parts Link below.
Happy Grilling!!
May 20, 2011 | Char-Broil Commercial Stainless Steel...
Need to know where to connect igniter button to where side burner is still connected not main burners
According to your Owners Manual, the side burner uses the same electronic ignitor as the main burners. I know that sounds odd, but that's what Charbroil often does with their igrills.
To help you with further insight and in case you've misplaced your Owners/Assembly Manual, I have included a link to it that you can download and print for future reference, if you like.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001189_463453306_english_37f8ef8b-0_.pdf
Happy Grilling!!
Apr 23, 2011 | Char-Broil Advantage 463453306
How do youremove and replace a charbroil gas grill burner on model number 463268007
Here is a link to the Owners Manual for your model grill. It has the assembly instructions, so just reverse what they are and you'll be in business. As they say, "one picture is worth a thousand words."
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463268007%20manual%20-%20english_3d4c7147-c_.pdf
Apr 03, 2011 | Char-Broil Grilling
Does the patio caddie use any kind of charcoal or lava rock
Your model Char-Broil LP Gas Grill use Lava Briquets on the lower grate above the burner(s). Any generic type will work. Just space them in evenly on the grate in one layer. You'll probably have some left over. So store them in an airtight container for future use (replacement).
Jan 26, 2011 | Char-Broil Patio Caddie 4654870 (LP) Grill
Ignitor
Check out the product manual, if you need a new one you can download free at Char-Broil.com. Should be a simple fix. Any problems and you can contact the company, they are most helpful!
Jul 02, 2010 | Char-Broil CharBroil 4637318 Grill
I have a char-broil Grill where the ignition wire came loose and do not know it came from
it come sfrom the ignitor on the burner or off the sparker /ignition button
May 20, 2010 | Char-Broil CharBroil 4637318 Grill
Only one of four burners will light.
Hello, there is a carry over tube between the burners that looks like a burner hold down at the back of the grill. This is likely rusted closed and will need to be cleaned or replaced. The clips that hold the tube down are part # 7000132 and the tube part # is 7000280. They can be purchased directly from Char-Broil or Sears parts.
http://www.searspartsdirect.com
If you find this helpful please vote yes. Thank You!!
Apr 19, 2009 | Char-Broil Advantage 463453306
Grilling Logo
2,427 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
