Question about HP COMPAQ Presario SR5410F Pentium dual-core E2160 1GB DDR2 320GB Intel GMA 3100 Wind... PC Desktop
Not sure about updated power supply
HP Presario SR5410F Desktop. Came with a 250W power supply. I bought a 650W supply. The old supply has a 20 pin connector for motherboard (MS-7525 Boston) and the new supply has a 20+4 connector. My motherboard has 24 pins. HP recommends only using the 20 pins. What will happen if I hook up the extra 4 pins? Does my motherboard support the extra power?
  • ntfd67 Feb 20, 2009
    Don't want to know that bad. Just thought someone might know why the extra pins are there if I'm not supposed to use them.
    President:
  • 2,692 Answers
Gee. If HP recomends you not to hook up the extra four pins it must be because the four either go nowhere,which may cause a short or ground condition.Or that the extra pins will power something that will then  be in excess andd cause it too burn out. They know what will happen and for that rwason caution you not to do it. Of course it is you machine and  if you have extra money to replace things with go ahead and do it if you really want to know that badly.
Posted on Feb 20, 2009
  • Thomas F. Schneider Feb 21, 2009
    You didn't like the answer, thought cmpletely true equates to a low score on you part. Your special.
Where can i buy a compaq presario power supply
Almost any standard ATX psu will fit this model, 86mm x 150 mm x 140 mm I would think. (PSUs come in standard sizes, most are ATX with depths into the case of 140mm upwards. Your old PSU s 140mm deep, so I should get one that also that deep. Higher powered ones can be can be as deep as 180 mm which wouldn't fit in your computer). It would be better if you bought a good brand one such as Antec, Corsair Silverstone, Seasonic, even an a Zalman or Akasa to name but a few, of at least equivalent power (it does not matter if it is a higher rated power, your computer will only take what it needs). Be certain that the PSU has enough of the correct type of connectors for your PC - Molex 4 pin power, minimolex for floppy if you use that, and SATApower if you have those, and 4 pin (I think for your pc) "P4" connector for your mainboard/CPU, and a 20+4 (20 pin with detachable 4 pin section for 24 pin m/b) pin motherboard connector. Be certain that it will accept the correct input voltage for your location (many will accept 90-240V ac now). You might try to get a second hand one.
12.April.2014
Jan 15, 2013 | HP Compaq Presario SR1750NX PC Desktop
Power supply watt
See it's label.
Take care!
damnor01
Sep 16, 2012 | HP COMPAQ Presario SR5410F Pentium...
Want to know power consumption of a hpsr5410f
The HP Pavilion w1907, 19 inch Widescreen monitor, RK283AA,
uses 49 Watts in operating mode, 2 watts in sleep mode.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00916924&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3351967
The Compaq Presario SR5410F Desktop PC, has a 250 Watt power supply. (Maximum wattage rating )
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01374067&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3686678
Theoretically.
Back in the day when this computer was made, Power Supply manufacturers were 'fudging' a bit on the truth.
(HP has their Power Supply's made by another company.
Bestec, HiPro, and Delta, are three of them )
Actual wattage is more like 60 to 70 percent, of what is stated.
250 divided by 10 = 25.
25 times 6 = 150 (60 percent)
25 times 7 = 175 (70 percent)
Your Power Supply's actual maximum rated wattage, may be as low as 150 Watts!
Going with the Power Supply produces a maximum of 250 Watts;
If you are playing an intense game, or have several programs running at once, you MAY reach using 250 Watts.
Just surfing the internet? About 100 Watts.
Desktop PC plus Monitor:
1) Surfing Internet: 149 Watts, or let's just say - 150 Watts
2) Computer is maxed out running hard?
249 Watts, or let's just say 300 Watts.
Voltage times Amperage = Wattage
Wattage divided by Voltage = Amperage
Number 1 above? About the power it takes to use a 100 Watt light bulb, and a 50 Watt light bulb. (Incandescent)
Number 2? About the power it takes to run three 100 Watt light bulbs.
(Incandescent)
Regards,
joecoolvette
Apr 16, 2012 | HP SR5410F 18GHz Presario Pentium Desktop...
Blue screen, dont want start anymore, giv m list of 10 problem
the most commom a recen hardware or software installation use safe mode to unistall it
second a ram memory damage
hard drive damage
corrupted files
faulty power supply...
May 24, 2011 | HP Compaq Presario Sr5410f PC, Refurbished...
I bought a HP 6710f Pavillion desktop, running windows 7, and found out it only has a 250 watt power supply. I turned around and bought an Antec Greenwatts 500 watt ATX 12v v2.3 psu to install for future...
Presuming you mean the Earthwatts 500:
Should work, though the Earthwatts has the 24 pin ATX instead of the 20-pin.
http://www.atxpowersupplies.com/manuals/Antec-Earthwatts-EA-500D-user-manual.pdf
You just need to snap the 24-pin connector apart to make it work as a 20-pin. It can be snapped back together for future motherboards.
The Bestec is just a standard ATX power supply
Mar 23, 2011 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
I have a compaq presario sr5410f that had pre-installed windows vista. i did a clean install using XP and now I need the XP drivers for the, 1. SM Bus Controller and 2. Video Graphics. HP doesn't have...
1. SM Bus Controller: http://www.fileguru.com/apps/sm_bus_controller_driver_windows_xp
2. Video Graphics. http://download.cnet.com/windows/video-drivers/
Oct 06, 2010 | HP COMPAQ Presario SR5410F Pentium...
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Computer won't boot up
Check the heat sink connected on your processor and its cooling fan is working or not
Apr 09, 2009 | HP COMPAQ Presario SR5410F Pentium...
Not sure about upgrading power supply
In many cases the additional 4 pin section slides up and off of the main power plug for use in your particular unit.
Feb 20, 2009 | HP COMPAQ Presario SR5410F Pentium...
Red Light on Board
it is better to use the old power supply because it is compatible to your mother board
Feb 11, 2007 | Soltek SL-K8AN2E (SL-K8AN2E-GR)...
HP COMPAQ Presario SR5410F Pentium dual-core E2160 1GB DDR2 320GB Intel GMA 3100 Wind... PC Desktop Logo
151 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
