Question about Acer TravelMate 2300 Notebook
Ive installed 160gb seagate 2.5 ide hard drive in my acer 2303lc when i put in recovery cd it says invalid system disk,replace the disk and press any key but when i press the key nothing happens ,its a new hard drive and i dont know if the drive has been formated and i dont know how to do it thanks
  • 2 more comments
  • pmdixon8 Feb 20, 2009
    these are the onbly 2 disks how do i format
    and it says media test failure ,check cable
    on the boot up it says media test failure ,check cable
    yes all of that is there
    Problem Solver:
  • 5 Answers
Your 2303 cannot carry hard drive that big. The specs state 80Gb max , but it should handle 120 Gb as the system will recognize up to 130Gb , but I have not tried it. MURRAY the MAGNIFICENT
Posted on Jun 01, 2009
  • Acer Master
  • 13,433 Answers
Hey,
Do you have more of those recovery discs? are you sure you have the right one inserted?
I remember on my acer I first had to enter a system disc, then when asked the two recovery discs.
If your unable to get it working with those cds I would suggest you get your hands on a original windows xp or vista installation cd and install windows from it.
also have you tried to enter the boot menu on start up? when you power up it says on some corner of the screen what button to press to get it to open the boot menu and then select the cd/dvd rom drive.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 20, 2009
  • 2 more comments
  • Ekse Feb 20, 2009
    try both cds in the drive and make sure you start them up from the boot menu, I think its F11 or F12. it says on one corner of the screen.
  • Ekse Feb 20, 2009
    Seems the computer is trying to start up from the network instead of the hard drive or cd.
    have you looked into the setup? I think its F2 button when you turn the computer on to enter the setup, look around the page and see if you can find details of the hard drive and the boot menu.
    the 160GB drive may be too big for the bios.
    you should see something like the above picture. see if you can find your hard drive model, from your computer, the same way its presented on this picture.
    Thanks,
    Ekse
  • Ekse Feb 20, 2009
    the media test failure comes when the laptop is trying to start up from network and the network cable is disconnected. it requires a special server to connect the other cable to inorder to start up from network, you can't use that feature.
  • Ekse Feb 20, 2009
    Ok, when you turn the computer on, it will say in one corner of the screen to press this button to enter boot many, press that button and when the boot menu opens select the cd or dvd drive from the list and press enter. if you still are unable to start up from the cd I suggest you try the cds on another computer to see if they work.
MY SATA 160GB HARD DISK NOT GO TO I AGREE OPTION THEN WINDOW INSTTALATION
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Jun 10, 2011 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
I HAVE MY MASTER 160Gb SATA SEAGATE, I HAVE TO ATTACH A NEW 500Gb SATA SEAGATE ,I'VE GONE TO BIOS SET UP. BUT IT DOESN'T DETECT MY NEW DRIVE.CAN YOU SHOW ME THE WAY TO SLAVE A SATA SEAGATE HARD...
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
May 16, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hi Ive got a dell 9400 that is running ok with a 54004rpm 100gb hdd but when I try an seagate 7200rpm/320gb it says no hard drive
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
Restart your computer with the XP Setup disk in the CDROM drive. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer. Enter your Administrator password. If you don't enter the correct password, you cannot continue. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed. Your damaged MBR will be replaced with a shiny new one, and you should then be able to boot your system normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead.
hope this helps
Apr 28, 2011 | CMS 160GB SATA 7200 RPM FOR 2.5 DELL M90...
Barracuda 7200.7 160gb IDE hd beeps and locks up computer when accessed, and only when the system tries to access it.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 29, 2011 | Seagate Barracuda 7200.7 160 GB Hard Drive
Acer Desktop Veritron M460 will not load Windows XP or Vista!
This problem may occur if the Ntfs.sys file is missing or becomes corrupted when you convert your hard disk to NTFS To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, anddrive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.I hope this helps.The other thing I can think of is maybe your harddrive needs a raid driver.If this is a sata drive and an old version of you os,the sata driver may not be already on the disk and you will have to insert one.Let me know if the first solution works,if not we can try the raid driver.
Apr 08, 2010 | Acer Veriton M460 Micro Tower Core 2 DUO...
Hard drive replacement. can I use 160Gb other than 120Gb original hard drive? how to recover data from dead hard drive? will Seagate replace the drive if it is over 1 year warranty?
If the drive is out of warranty then no....seagate will not honor an expired warranty. As far as the swapped hard drive yea you can swap for a larger drive as long as it is the same dimention (2.5/3.5 ect) and connect (SATA/PATA/ATA/IDE) as far as loading windows you are gonna have to get your hands on a usb cdr drive....either that or create an ISO image of your operating system on a sd card. Good luck
Nov 12, 2009 | Acer TravelMate 8200 Notebook
I JUST CHANGED MY HARD DRIVE FROM 80GB TO 160GB BUT IT WILL NOT LET ME IN MY PC COMES UP PXE-E61: MEDIA TEST FAILURE CHECK CABLE PXE-M0F:EXITING BROADCOM PXE ROM NO BOOTABLE DEVICE- INSERT BOOT DISK I...
When your new hard drive is installed does the Bios see it?
If not then you have an issue with the hard drive. Quite often this issue can be resolved by simply removing the IDE cable blowing out any dusk and reattaching it.
If that doesn't work try disabling the LAN boot option. You can also try changing the HD from ACHI to EDI, changing the Boot order and/or simply resetting the bios.
Try these and if you have no go for launch repost what you did and I'll try and help from there.
Hope this helps.
Oct 22, 2009 | Acer Aspire 5315 Notebook
Seagate SATA 80GB Master Drive and Seagate IDE 80GB Salve Drive
Dear,
You have to make IDE drive as slave. For this put the jumper to slave in IDE drive. Possibility of CMOS battery is rare, but you can confirm it by checking your system time in BIOS. If system time is ok then there is no problem in CMOS battery and you need not to replace it.
Thanks,
Rakesh Kumar
Jul 23, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Computers & Internet Logo
152 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
